Correct if I'm wrong, but didn't Ford get in trouble a while back because of the cvt trans in the Fiesta?
Has Ford improved their cvt transmissions?
ECVT is great and makes a lot of sense because virtually nothing is rubbing.Correct if I'm wrong, but didn't Ford get in trouble a while back because of the cvt trans in the Fiesta?
THIS Everyone hears CVT and thinks Nissan, and Subaru and while those two have their problems they’ve come a long way. I have a Outback with a CVT and it’s a great in-town driving experience, which is primarily what the Hybrid Maverick is designed for. However my main gripe with the CVT is how “tall” the “first gear” is, it takes a good prod to get it moving, so if you don’t baby it off the line you lose most of the supposed fuel savings the efficiency of the transmission design is supposed to give you.I sold my Commuter car (2020 Toyota Hybrid) and ordered this truck on the 9th. I can tell you if the ECVT works as well as the Toyota you will be happy.
That’s the issue with belt CVTs. Very inefficient at the low and top end of the ratio range. The geared CVT should be much betterTHIS Everyone hears CVT and thinks Nissan, and Subaru and while those two have their problems they’ve come a long way. I have a Outback with a CVT and it’s a great in-town driving experience, which is primarily what the Hybrid Maverick is designed for. However my main gripe with the CVT is how “tall” the “first gear” is, it takes a good prod to get it moving, so if you don’t baby it off the line you lose most of the supposed fuel savings the efficiency of the transmission design is supposed to give you.
ECVT is what is in the Prius and it is a perfect match to the smooth in-town experience the Hybrid Maverick is designed for.
Ford CVT Problems (itstillruns.com) Ford's eCVT is extremely similar in design to that used on the Toyota Prius. Should be extremely durable. Look at the attached website.Two things:
1. The Fiesta (as far as I know) never had a CVT. The problem trans was the DPS6, a Dual Clutch box.
2. The CVT in the Maverick is not a CVT as you know them to be, with belts and pulleys. It makes use of a single planetary gearset and two electric motors to create infinite ratios. Because the motors are what drive the wheels, many people say the system feels a lot like an EV.
TYVM This helps a lot to ease my concerns about the CVT used in the Maverick.Ford CVT Problems (itstillruns.com) Ford's eCVT is extremely similar in design to that used on the Toyota Prius. Should be extremely durable. Look at the attached website.
My son is still driving my 2007 Camry Hybrid at 370k And no tranny issues at all. I have no idea if it is a cvt or an ecvt, I just know it was fun when both motors spool up under hard acceleration and no transmission shift. So if it is as good as that one…Correct if I'm wrong, but didn't Ford get in trouble a while back because of the cvt trans in the Fiesta?
The article quoted is not the eCVT in the Maverick, it is an entirely different transmission. The eCVT does not use a chain or cones, it is entirely gear driven.Ford CVT Problems (itstillruns.com) Ford's eCVT is extremely similar in design to that used on the Toyota Prius. Should be extremely durable. Look at the attached website.
