- Oct 26, 2021
- Farmington Hills, Michigan
- Maverick XL Hybrid
- Engine
- 2.5L Hybrid
Yep - this prob was reported quite a while ago and some reliable Ford sources identified the root problem and had specific metrics on the quantity of the flawed cranks, there were a couple/few fires and engine breakdowns that made them go looking for the root cause and eventually they identified it but the downside was that the flawed ones just made it into the mix of all of them and post production months later the incidents occurred so the old horse was out of the barn. Problem was exacerbated because of the lack of drain holes so if you have one and the engine starts smoking and spewing oil it just sort of sits there and (can) ignite, so it's a two fold problem and that's why they went the route of porting some holes to at least have the oil seep thru and help eliminate potential fire but that doesn't address who might have the ticking time bomb. So in the meantime it's just like they say if you see smoke pull over and shut it down. Your idea re fuel pump shutdown is reasonable with the cavaet that the elec engine should still be operational for a short while so you can safely pull over - just disabling both might be dangerous as if you're on the xway and you just shut down well that might be even more trouble. Fire exting is a good idea, no harm in it. I'd guess that if/when they do id the flawed engines they would likely drop a new engine in - can't see them just buying you out.Got my letter yesterday also.
Sounds like you know some facts about the cause of issue....and not some wild guess. Wild guesses do none of us any good. As a software developer, I can easily see a diagnostic error turn off an engine or fuel pump to stop a fire.
I got my first recall letter on this issue back in Sept and dealer keeps telling me parts are not available...but from your comment it may not be a need for parts, but more testing of oil analysis.
As a precaution I have two gas fire-extinguishers and know if I see a fire, do not raise the hood but release spray through the grill or crack in the hood.
Not worth posting but my Ford dealer service rep told me that Ford only knows of 4 or 5 fires out of the thousands of Hybrids they have in service.
