First Oil Change Mileage and Oil Type (Blend or Synthetic)?
Hambone
Tennessee
Rav4
Im sure this has been discussed. But at what milage did you do your first oil change, and did you go with blend or full synthetic? (HYBRID)
Im going tomorrow, dealer recommend 3000miles and using a blend.
Rod
Rod
Indiana
Wow, your dealer is trying to create business isn’t he..The hybrid will go about 10K between oil changes and the manual Calls for full synthetic..Why would you just follow that?
Bob The Builder
Butch
Vermont
Not sure about hybrid but my EcoBeast will be 1500 miles. Mobil One. Motorcraft 910-S Filter. Still got 400 miles to go. After that first change, every 3K miles or one year whichever comes first.
Clarkdonbran
Dealer is blowing smoke. PassApp shows oil life. Mine has been almost exactly 10k miles.
Scooter66
Scott
Saint Augustine
2016 Ford F-150 Lariat
I’m in the 1000, 3000 and then every 4000 after. Mobile 1. I had my 22 2.0 FX4 for 18 months and now I have an all black 2024 2.0 AWD LUX/BAP 4K XLT. Just changed the oil Saturday (DIY).
Justin says...
Justin
NC
'22 Ranger XLT
I just completed my first oil change at 1,242 miles. Since the dealer owed me a free oil change from screwing it up on my previous vehicle, I had them use full synthetic. I wanted the first one done at 1k miles, but life got busy as it does.
From here on out, I plan to do it myself (and my dad's Mav) using Pennzoil Ultra Platinum and the extended-size filter made by Wix at 5k mile intervals.
RedRider
Kitchener, Ontario, Canada
2013 Fusion, 2023 Maverick on order
Full synthetic meeting the Ford spec is the only oil you're supposed to use in a hybrid. The dyno blend is only ok in the EB, with shortened change intervals. Find another dealer who actually reads the spec.
Ozarkbeard
NW Ark.
'23 XL CP360
Find another dealer because yours is an idiot. If you'll RTFM, it will tell you your hybrid needs full synthetic 0w20.
As for oil change interval in your hybrid; probably do it after the first few thousand miles. After that, use the Oil Life Monitor built into your truck. It takes a lot of things into consideration besides miles. Example: The total miles shown on your odometer are significantly more than the number of miles on your Hybrid's gasoline engine, because it doesn't run a lot of the time. Your Hybrid will need much less frequent oil changes than a comparable Ecoboost non-hybrid Maverick.
Modesto
Barry
Tampa Bay
Maverick XLT
I had the first one done yesterday at around 5,000 miles and the tires rotated as well. The tech came to the house to do the two recall updates, and took care of the oil and tires.
jaybird
Lake Norman NC
www.youtube.com
2022 Maverick Lariat , 2023 Maverick Lariat
I Would go 5k If you wait for 10k you are asking for sticking rings and a oil burner at 100,000 miles! I'm a 25 year ASE Master Tech, 15 year Ford Instructor.
Oscarcat
Eric
Encinitas California
'22 Lariat, Lexus NX 300 Chrysler PT Cruiser 5 spd
Yes, lots of discussion about this. 24 hybrid = first change 1500 miles in my garage using Mobil 1 hybrid specific full syn and a Motorcraft 910S oil filter purchased at Walmart.
Hybrid specific oil has extra additives to reduce acids that form in the 2.5L Atkinson cycle engines because in the city stop and go driving where the hybrid shines, the engine may not get up to operating temp long enough to burn off the moisture that causes acid to build up.
My dealer uses a "blend" [ blend cheaper than full syn] and had no clue as to whether it was hybrid specific [probably not]. Plus, I am certain they don't wait for the old oil to completely drain.
That said, changing oil even at the dealer is better than not changing it at all.
I use "Redneck ramps" - I drive up on two crossed 2x6's under each front wheel to give me the clearance I need to access the shield, drain plug and filter.
I put my used oil back in the now empty jug from the new oil and take it to the local auto parts store that recycles used motor oil, a toxic substance.
Vettereddie
MD
2023 Maverick XLT
Based on RTFM (page 453), Intelligent Oil-Life Monitor determines the change interval based on driving habits, no fixed interval.
Page 454 gives guidelines on expected interval based on usage but does not distinguish between EcoBoost and Hybrid. I would assume hybrid interval is greater due to lower engine use while in electric mode.
- Normal: 7,500 - 12,500 mi (Normal commuting with highway driving; No, or moderate, load or towing; Flat to moderately hilly roads; No extended idling)
- Severe: 5,000 - 7,500 mi (Moderate to heavy load or towing; Mountainous or off-road conditions; Extended idling; Extended hot or cold operation)
- Extreme: 3,000 - 5,000 mi (Maximum load or towing; Extreme hot or cold operation; Extended engine idling)
Do not exceed 1 year or 12,500 miles between service intervals.
Manual recommends for the hybrid 0W-20 Full Synthetic oil ONLY, no blend, meeting the WSS-M2C962-A1 specification.
Personal preference, I did my first change on my 2023 XLT Hybrid at 6 months / 7,500 miles with about 36% remaining oil life. Used Mobil 1 Advanced Fuel Economy 0W-20 full synthetic and a Mobil 1 M1-102A filter.
Mobil 1 0W-20 Full Synthetic, Super Synthetic, High Mileage, Extended Performance, Extended Performance High Mileage, Advanced Fuel Economy, Hybrid, and Truck & SUV all state they meet or exceed the requirements of WSS-M2C962-A1 with differing mileage guarantees.
AutobahnSHO
Will
S.Carolina
Miata, Hybrid Mav, Odyssey
Manual says which oil should be used.
I had recall and issue so asked for first oil change at dealer with 6200 miles. They put a sticker on windshield that next would be 5k miles later.
CHECK THE FORDPASS app, it probably has the oil life%.
svogt302
NJ
2012 Mustang Boss 302, 2019 Ranger
Personally, I cut Ford's recommendations in half..... To each their own.
