- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
I forgot to mention and will edit the post the engine oil suggestion I was using is for 2.0L ecoboost engines not the hybrid. I don't know what nuances need to be taken into consideration for those when considering engine oil besides what weight oil is recommended in the book.Nice breakdown. As long as the oil used meets or exceeds the "ford standard" it should be fine, as far as overall performance. I know that for the hybrid it says I need to be using the WSS-M2C962-A1 which corresponds to https://www.fcsdchemicalsandlubricants.com/Products/Details?cid=70&pid=474 (happens to fall into the GF-6 and API SP/SN+ categories. We have to remember that some of these specs have nothing to do with physical performance of the lubricant, but which types of seal materials or other components with which the oil may come into contact with. Just like ZDDP or sulfur phosphorus additives that help with pressure and wear, these additives can become aggressive towards specific materials in the right conditions (anyone that has had to rebuild a worm drive and found that the bronze gear looks like it was eaten by something, that was the extreme pressure additives eating the gear).
So yes, use whatever oil you want, just make sure that it meets the applicable standard for your vehicle.
