Eldrick1
NW Suburbs Chicago
2024 Maverick
Used alternate coding #3 to disable seat belt popup screen and works perfectly. Screen nags if belts undone and disappears immediately when belted. This is exactly how I want it to work. Thanks again to all who make things like this possible, and so easy for the rest of us dummies!
EONR24
EONR24
Swag
United States
2024 Ford Maverick XL
This is how it should come from the factory I think! and no problem! Thanks for your comment!
Keller5158
Usa
2024 Lariat hybrid
Has anyone figured out how to get the belt light only? So far managed:
No belt monitor
No belt minder
No belt chime
No belt light
Belt monitor
No belt minder
No belt chime
Belt light
No belt monitor
Belt minder
Belt chime
Belt light
I'm trying for:
No belt monitor
No belt minder
No belt chime
Belt light
So far the strangest is having the belt screen appear, but remain blank.
2024 Lariat hybrid
EONR24
EONR24
Swag
United States
No belt monitor
No belt minder
No belt chime
No belt light
Belt monitor
No belt minder
No belt chime
Belt light
No belt monitor
Belt minder
Belt chime
Belt light
I'm trying for:
No belt monitor
No belt minder
No belt chime
Belt light
2024 Lariat hybrid
let me see if I can figure it out if there's a way
Toddman45
Todd
St. Louis, MO
Can this be done in EZ Mode? Tia
EONR24
EONR24
Swag
United States
bump for the new owners
C'ville
Eli
Charlottesville, VA
Ford Maverick Tremor
Hello everyone!
EDIT: CHECK OUT MY OFFICIAL FORSCAN MAVERICK SPREADSHEET HERE!
I finally found the way to disable the ANNOYING Seatbelt information screen that comes on when you start the truck and stays on even after you buckle your seatbelt. Thank you to @ZOODAD over on the F250 forums for the coding information. THIS SUPER DUTY spreadsheet he put together might be useful for future MAVERICK FORScan Mods. THIS IS CONFIRMED TO WORK FOR ALL 2022-2024 MAVERICK TRIMS!
DISABLE SEATBELT INFORMATION SCREEN
1. Open IPC AS BUILT
2. Change line 720-13-01 and 720-13-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
3. Change line 720-14-01 and 720-14-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
These changes remove the seatbelt info screen pictured below entirely and it also disables the seatbelt chime too. I would love to hear from other members to see if these changes work in your Maverick! Tested on my 2024 Maverick XL AWD ECOBOOST with the smaller instrument cluster. (The 4 inch Instrument Cluster)
EDIT: ALTERNATIVE CODINGS to keep the seatbelt minder (chime and dash light) but disable the seatbelt monitor (information screen) are linked HERE , HERE and HERE !
ALSO, Here is a link to 2 more changes that DISABLE DOOR AND KEY CHIMES and I went ahead and listed them below! I have successfully tested both of these coding changes!
Let me know if these codings work for your Mavericks out there!
DISABLE DOOR CHIMES
1. IPC AS BUILT
2. Go to 720-01-02
3. Replace the third digit with a "0" as shown here
xx0x-xxxx
4. Write the changes and let Forscan correct the checksum
DISABLE KEY-IN IGNITON CHIME
1. IPC AS BUILT
2. Go to 720-01-02
3. Replace the sixth digit with a "2" as shown here
xxxx-x2xx
I just tried this on my 2024 Maverick XLT Tremor. The chime turned off but the seatbelt screen wanting the ok was still there. I had previously followed the directions from the manual to turn off the chime but it never worked. Forscan did work for that.
Dignam
Madison, WI
'25 Maverick Lariat
Works for mine. I changed the as built values from page one of this thread. If you only change only the first group of values, you'll still get the dialog prompt with 'OK' button, just with no info on it. The 2nd group of values will disable that dialog altogether (along with chime and light). Thanks, OP!
EONR24
EONR24
Swag
United States
Zero out those 4 lines of codings completely. It will work.
Toddman45
Todd
St. Louis, MO
Omg, it worked. Thank you, thank you, and thank you very much.
NM Bob
Las Cruces, NM
2024 Ford Maverick Lariat
Hello everyone!
DISABLE DOOR CHIMES
1. IPC AS BUILT
2. Go to 720-01-02
xx0x-xxxx
1. IPC AS BUILT
2. Go to 720-01-02
xxxx-x2xx
Hello everyone!
DISABLE DOOR CHIMES
1. IPC AS BUILT
2. Go to 720-01-02
xx0x-xxxx
1. IPC AS BUILT
2. Go to 720-01-02
xxxx-x2xx
OK, dumb question... Is the 720-13-01 and 720-13-02 change for the screen and the 720-14-01 and 720-14-02 for the chime or are they both necessary to change the screen??
NM Bob
Las Cruces, NM
This is what's working for me. '24 XLT Hybrid.
No message if driver is clicked in. Pops up if not.
Goes away immediately when clicked if message is showing.
Indicator should still work for all seats.
I changed this so that it won't ding at me at startup.
Big thanks for this one! I used these codes on my 24 Lariat EcoBoost and it worked perfectly. My main complaint it was that it took forever for the screen to go away unless you clicked ok. But like you I always wear my belt so as soon as I buckle it the screen disappears. While I was at it I also disabled the double honk when getting out of the running truck with the fob in my pocket. That was soooo annoying! Also I installed the bypass module to keep the engine running when at a stop light. I think the truck is now just about perfect!!
