"F it, it's just plastic" Tiny modification to trim for dashcam wires
clavicus
I kinda avoided doing this for a while even though I knew I should... just cut out a little bit of the black plastic BLIS camera cover trim to get my dashcam wires out of sight. Very tiny modification but I thought it would be nicer to have the wires gone. My drill bit jumped a tiny bit in my feeble attempts to be accurate while making the cutout.
I started out with the drill press which actually worked pretty well to cut the general shape of it. Then a round file to eat out the extra plastic, but I realized the file was a bit larger diameter than I wanted, so I tried to carefully use a dremel with a cutoff wheel at a slow speed, but that was kind of unwieldy... then tried free-handing with a drill bit in a cordless drill. Went back to the file and just committed to the file diameter even though it was larger than I was going for. Cleaned it up with some high grit sandpaper.
5/10 job visually, but success 🍻
Ford Maverick "F it, it's just plastic" Tiny modification to trim for dashcam wires 1646782409876
Ford Maverick "F it, it's just plastic" Tiny modification to trim for dashcam wires 1646782420051
Ford Maverick "F it, it's just plastic" Tiny modification to trim for dashcam wires 1646782437582
KenC
First
Earth.
Truck.
Are you using a power source behind that plastic for your dash cam?
clavicus
clavicus
