EB 2.0 battery replacement...
bgn
WA
My second EFB battery won't charge more than 65% or so. Maybe the third battery is the charm...
Might stop by an auto parts store to see if they can test it for me.
jalbano2
JAMES
NY
2022 Maverick Lariat Lux, EB , 4k , FX4 , Moonroof
Similar to my electrical system, most of the times the start/stop disabled by the system due to not enough charge in the battery. The battery also does not hold the charge in my case. After driving the truck for 10 - 15 minutes and the alternator fills up the battery enough, the system may, or may not enable the start/stop 1-2 times, then disables it again. It's a crappy battery...
EXACTLY!!
Skyline
Skyline
Skyline
'24 Honda Ridgeline
While I test the battery myself, you had a good idea, and will take it to a parts store.
Based on your signature, " Good Mavericks come to those who wait.... ", maybe we didn't wait long enough... :ROFLMAO:
Tim d
Alpena
Ram
Negative!! Defective. Nothing is killing it. The voltage is just low enough to prevent the stop start from working. That is enough for a warranty exchange..
Ah,so a bad battery from the factory.glad it's covered under warranty!
Exranger
Northern California
AGM batteries last 3 - 4 years, depending on number things, including driving...
The battery in my truck does not hold the charge:
Getting the battery replaced by the dealer is a crapshot. They may, or may not have it in stock in which case, it needs to be ordered. Based on my research for the OEM battery, even Ford website has it back ordered. With that stated, the truck is going into service next Friday in case they have one, or can get one in reasonable time frame.
Winter is just around the corner and I would not want to go into it with a crappy battery. The third-party batteries are batter than the OEMs and I want to change it. I've been changing batteries in my vehicles ever since I have one, was just looking for any "gotchas" in changing this battery....
Thx...
Ford batteries are good with a great warranty. Call your parts dept and order your battery, you won’t have to pay for it. Get it in, then if you need one it will be in stock and you can release it to yourself under warranty. Cheap easy insurance. I’ve done it before and it works. Good luck. Also test system to see if it is causing batt failure.
Skeeter163
Don
Hertford NC
2017 Escape
The battery should last 8-9 years, curious why you would want to replace it already?
I just replaced the exact battery in my 17 escape. It was the original
It is a Agm Motorola made in China .sticker on it says so. Got 6 yrs out of mine. Wonder if is the same on my 23 Maverick hybrid?
ps. It costs $257.99 at the dealer.
Skyline
Skyline
Skyline
'24 Honda Ridgeline
In my previous post, I didn't know the purpose of the wiring between the positive and negative terminals of the battery. The video below pretty much cleared it up for me:
There are some interesting details on how to charge/jump start a Ford vehicles equipped with Battery Monitoring System, or BSM.
Some other interesting details is, that Ford sets the limit for charging the battery with the BSM, around 75 - 80% based on this Rangers forum posting. Adjusting the limit to 90% via ForeScan resolved some of the similar issues in the Rangers. The chances are the same could be done in the Maverick as well with similar results.
These are good to know and may just use ForeScan for increasing the charge limit...
B2000
midwest
B2000
Very interesting video. From what that guy says my trips of 15-30 minutes may not be enough to charge my battery even if I drive every day because of the electrical demands of the vehicle and the charging limits established by Ford. That may be what my service advisor was trying to get at although he did not provide anything close to the info in the video nor did he ever call me back.
He said my state of charge was only 56% when I took it in. Obviously start/stop will not work at that level but if it gets any lower when the weather gets cold I don't know if starting will be a problem or if other features will shut down. Of course I can hook up a battery tender but that seems like kind of a pain for a vehicle that is regularly driven. Even worse would be driving unnecessary miles just to charge my battery- that kind of goes against all of the stuff we are doing to increase efficiency and mpg.
I may hook up a cheap battery monitor and see what that tells me- looks like there are some for under $30 that hook up to an app on your phone.
Bob The Builder
Butch
Vermont
I drive so little my A.S.S. quit working soon within days of bringing the truck home. Going to be interesting to see how she starts @ -35F. Should be planning on a battery tender as I tend to drive even less in the winter. :confused:
Two different issues here. Defective batteries is something that Ford should have realized and fixed a long time ago. Second issue is lousy implementation of the BGM the way I see it. My wife's Jeep has BGM, we drive it very little and never any issues with the original battery. It has never given low battery warnings, stuff shutting down or the like. It just works.
Ford needs to figure it out. No one should have to keep charging their battery on a $75,000 truck just because they do not drive 2 hours a day to go to work. Gimmee a friggin' break here.
Nw_adventure
Salt Lake city
Bought my EB back in December of '21 . I have had my battery replaced twice under warranty (Most recent 11/1/23) Both times with the newer AGM ford battery.
Same - Fords AGM batteries have been failing. I was almost stuck in BFE due to a 5 month old AGM losing a complete cell -
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Thanks for posting this.
On my previous 2022 Ford Maverick XLT Hybrid I had a few "Deep Sleep" issues because of the many short trips I take because I am retired so no long trips to/from work. Most of my trips are 1 mile in length.
I have an old charger from the 80's and directly charged the battery at the terminals overnight.
From this video I now know that is the wrong way to do it.
I did charge overnight so maybe the Ford failsafe caught me doing the charging incorrectly and had the BMS software update because of that.
I also did manually reset the BMS to relearn the battery charge state.
On my 2023 Ford Maverick XLT Hybrid I have not had any "Deep Sleep" issues so far and the battery voltage seems to be keeping to the upper 12 volt range unlike the 2022 where I would see the voltage in the low 12 volt/high 11 volt range just before the "Deep Sleep" warning happened.
If I have to ever charge the 12 volt battery I wonder if hooking it up to the jumper charge posts under the hood would be better.
Here are some photos I have from my 2022 Maverick Hybrid showing charge states, charge tester and charger.
"Deep Sleep" warning and Ancel Tester showing 0% Charge and 0% Health with 11.77 Battery Voltage
Ford Maverick EB 2.0 battery replacement... 2023-01-25
After overnight charging: 13.11 Volts and near 100% charge and health
Very old Kmart Charger
Ford Maverick EB 2.0 battery replacement... Kmart Charger
Skyline
Skyline
Skyline
'24 Honda Ridgeline
I don't disagree, but Ford and others will keep doing this for a few reason.
I am glad that the video helped....
Being lazy today, NFL Sunday, etc., how do you reset the BMS manually?
Thx...
Thanks for finding and posting that very informative video. So far I've never had any issues at all but if i were to have any battery related concerns i would have been charging the old school incorrect way with this new technology. Now i know the correct process.
huunvubu
coppell tx
Thx...
Ford Maverick EB 2.0 battery replacement... Battery Sensor Reset and BMS Syatem
jalbano2
JAMES
NY
When they replaced the original standard battery with an AGM I was happy and thought that should fix the issue but less than a year later same problem. Who makes FoMoCo AGM batteries? Anyone know?
