Are ramps necessary for DIY hybrid oil change?
BlueSpec1
Gene
sanpablo
Rich
Long Island, NY
Title says it all?
I bought these ramps, lifts the Mav a little under 3 inches. Should be enough room for oil change. If not I'll use my floor jack and jack stand.
Ford Maverick Are ramps necessary for DIY hybrid oil change? IMG_20231110_125109
Ford Maverick Are ramps necessary for DIY hybrid oil change? IMG_20231110_124810
Ford Maverick Are ramps necessary for DIY hybrid oil change? IMG_20231110_125043
Ford Maverick Are ramps necessary for DIY hybrid oil change? IMG_20231110_125904
colinl
Colin
ICT
Funny someone mentioned brewing because I've changed the oil in my car while brewing beer and neither activity was impacted time wise 🍺
beer was pretty dark, I bet? ;)
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Yea not enough space to crawl underneath.
That said, you can get to the tranny drain plug without the ramps and it's advisable since it would keep the truck level without having to jack the entire truck up. Simply turn the wheels to the left and there ya go. You will need an extension though...
I wouldn't even use that on a bicycle. ProjectFarm just did a good video on Jack Stands just did a good video on Jack Stands and it's pretty surprising how many cheap flimsy stands are sold now days.
For those interested here is the ProjectFarm video on Jack Stands:
zeen
Don
'24 Mav Lariat, '15 Suburban, '91 SL500, 76 VW Bus
Very cool, if they aren't too expensive. I tried crawling under my hybrid before changing the oil, and it was too low. I ended up rolling up on a couple of 2x6s, which was barely enough. This seems like the perfect height, and more professional than 2x6s.
sanpablo
Rich
Long Island, NY
$40 from EBay for the ramps.
Montana
And some chock blocks hopefully.
JBL14
Co
Old cars
Don't think I could have changed the oil/filter without ramps.
- there are a boat load of torx screws holding the bottom baffle thing on. The screws toward the rear would be particularly challenging to remove without [safely] lifting the vehicle a bit, imo.
- the factory oil filter seems to have been installed by Thor... so I appreciated the extra space to wrestle it off
- free tip: I covered the lower coolant hoses with a plastic bag (pictured) to shield against drips coming out of the filter housing when spinning the old filter off.
Not sure it will be easy on Maverick but try punching hole in filter first.
sanpablo
Rich
Long Island, NY
S Dundee
Guest
I prefer jackstands over ramps. Easier to store, less hassle driving off the ramps.
Doing it yourself takes away worry someone lost fasteners or torqued the plug down stupid tight.
Really true. A friend has a Toyota with free 2 year maintenance and the dealer put back a dirty cabin filer and used an airgun on the bolts for the splash pan. He spent more time correcting the "free service" and at the dealer complaining about it than if he had done it himself.
zeen
Don
Good idea. I'll give it a go next time. Thank you!
I tried that. It helped a bit, but enough oil still spilled out upon removal that it didn't matter.
