Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
You can apply a wax over coating. I apply a strong sealant over my coatings so that the sealant is taking the brunt of the elements and the coating is preserved under it just like the clear coat is preserved under the coating. Theoretically, you do this and the coating will last damn near the cars lifespan.
Sorry for all the questions: (be easier if you just wrote a book)
Have a brand name for a "Sealant" to top off the Ceramic Coating???
Delzona
Tucson, AZ
No they’re all done in a specific pattern. We take multiple readings of each panel to get accurate results. You can go from bottom of door to top of door and see a 1-2 Mil difference easily. Makes you wonder what in the world theyre doing in the paint booth. All four corners of each and every panel gets hit and a reading or two in the middle. Tailgate was a no-go, all readings were 2.2/2.3. Bottom of driver door was 2.5/2.6. Driver passenger was all just under 3 Mils. Roof and Hood had the 4 Mils and everything else was pretty much low 3s. I can post a report I did recently on a brand new Dodge Ram 1500 that had 3-4x the paint I have on my Maverick. It’ll make more sense.
View attachment 51347 View attachment 51348 View attachment 51349 View attachment 51350
That's a big difference in paint thicknesses when compared to the results you got on the Maverick!
projectvortex
Thanks. This is great information. I’m no expert in automotive assembly line painting but I have to guess that some body panel members are painted differently from others……dip vs spray vs ……?
Dulce21
Grace
BMW 3 series
I’m just gonna start by saying that these Mavericks are already head turners when they’re out in the wild… But now this thing straight up is snapping necks.
Finally had the time to detail my truck properly. It was washed, decontaminated and pretty much every surface is now ceramic coated. Paint was in such good shape after washing and prep, that I fortunately didn’t have to do any paint correction. This is rare but shows how taking the proper precautions and making sure your vehicle is in professional hands can save you a lot of time and money. This truck is Ceramic Coated so it’s UV protected, it’s going to stay cleaner for alot longer, it’s going to stay looking glossy and cleaning it is going to be a piece of cake thanks to the low surface energy and high contact angle the ceramic coating provides. This is going to protect my vehicle from things like bird scat, insect acid, hard water, acid rain, road salt and much more.
Here are a few thoughts..
1.) Don’t let your dealer touch the truck. This is going to prevent you from having to pay to fix any scratches/imperfections they administer. This is important because polishing is where you’re going to spend your money at the detail shop.
Warning: these trucks have little to no paint on them.. (more later on)
2.) Find an certified detailer with proper knowledge and experience and don’t let joe shmoe touch your truck. You get what you pay for quite literally in the detailing industry. You can always find someone to do it cheaper, but that’s not necessarily better. You’ll usually end up paying another detailer to fix the first ones mistakes. In this case, not hiring a professional could easily lead to them burning through the little paint you have trying to correct it.
3.)PAINT IS THIN
This is so important. If you or your detailer are going to polish the truck in any way, they NEED to do a paint reading with a paint depth gauge. Paint preservation is most important.
I was shocked at how little clear coat was on certain parts of my truck and had I not taken the right precautions and measured the paint, I’d be in a lot of trouble. Luckily I had no dealer instilled scratches or swirls and I was able to simply wash, carefully decontaminate the paint with an iron remover, sap remove, tar remover and followed up with a careful claybar. No user inflicted marring. Had I not been experienced at this, this would have been a turning point in the project for a lot of people. I’m shocked at how thin the paint is and so thankful I am not busting out the polisher. Below are pictures of the process and what I saw.
4.)Plastic almost appears to have a coating of some sort on it. I ceramic coated mine but it almost didn’t want to take the coating. Hopefully we won’t see fading down the road like we do with most vehicles with this type of exterior surface. Whether your coating it or restoring it down the road, remember these pieces are very porous and get clogged with contamination. It needs to be cleaned properly or you won’t get proper adhesion.
Here are pictures of the process, hope you enjoy.
Before:
After:
Clay After Decon: lots of dirt and grime embedded into the clear coat
Paint After Clay: No visible scratches or marring when done right
Measuring The Paint:
Results: For Reference, you can assume you have about 1.5-2. Mils of base/color coat on a car. 1 Mil is .001 of an inch. For reference, a post it note is 3 Mils thick. So most cars paint is thinner than a post it note. Most new cars have about the same amount of clear coat, sometimes less and sometimes more. After reading as low as 2.28 on some places that’s a sign there is very little to no clear coat on these vehicles.
Coating Time:
Gtechniq CSL Followed By ExoV4
Beyond happy with the results!!!
Hope you enjoy and thanks for reading!!!
Hi I had my maverick ceramic coated and wrapped all the front. I love the results and would do it again.
Bob W
Sun Lakes, AZ
2016 Kawasaki Versys 1000 LT
Wow this truck looks amazing!!! Any recommendations where I can find a similar level of work in Los Angeles?
Phenomenal difference! Know anyone in the Phoenix area?
AUTUS_FL
Paul
Saint Cloud, FL
2022 FORD MAVERICK XLT HYBRD;2021 HONDA REBEL 1100
Yeah I have, at the shop I used to work at we used XPEL Fusion Plus over all of our XPEL PPF jobs. Solid stuff IMO.
I am also wondering, will the ceramic coating protect the paint from rock chips and scratches at some degree? Thanks again!
Hdang1980
Elk Grove, CA
2022 Ford Maverick Hybrid
3.)PAINT IS THIN
Before:
After:
Coating Time:
Your post has inspired me to ceramic coat mine. I'm not a professional detailer, but I do I have a YouTube premium account. LOL I plan on giving her a wash, iron remover, claybar, and then ceramic coat. Are you familiar with Ethos Pro Ceramic Wax? What are your thoughts?
Icatchshrimp
Toyota Corolla
3.)PAINT IS THIN
Before:
After:
Coating Time:
That’s amazing results. Thanks for sharing
Ranchlife
Henry
Southern California
Chevy PU,Toyota PU,YJ JEEP,Fusion,Elantra,Sonata
3.)PAINT IS THIN
Before:
After:
Coating Time:
Damn...that is nice, completely changes the color.
