12V battery type
NJBob
New Jersey
I understand that the 12v battery in our Mavericks is an AGM. Guess that means I can't use my 45 yo Heathkit Automatic batter charger. Damn that thing served me well.
NoVaJimmy
KCMO
Lexus GX 460
Incorrect. It's a filled type battery. Source: I replaced mine for an AGM so your trusty charger will charge on.
NJBob
NJBob
New Jersey
That's great! Not sure where I read that. I have seen agm for motorcycles but never car size. Thank you.
23MAVLariatAWD
VA
RECEIVED '23 Hybrid Lariat Mav Oxford White BAP
Hey Jimmy what exact AGM battery did u buy to replace it and where did you get it? Thx in advance-
NoVaJimmy
KCMO
Lexus GX 460
Keep in mind that I have an ecoboost which has a completely different 12v battery size than your hybrid. That being said I purchased an Interstate. They didn't have the Maverick in their system yet so I just spec'd a Bronco Sport Badlands since it has the same 2.0 and battery from the factory.
NJBob
NJBob
New Jersey
What's the big advantage in an agm anyway. I know you can mount it in any position. But what else? Like maybe for replacement times I'd do it. But not to replace an good battery.
NoVaJimmy
KCMO
Lexus GX 460
An AGM can survive a deep discharge that would otherwise kill or damage a flooded battery. They're also able to be charged up to five times faster than a flooded battery. The significant advantage there is that you can update the BCM in the maverick with forscan to let it know you're running an AGM battery which in turn will allow the charging system to "give it the beans" and hopefully negate running into any deep sleep issues.
NJBob
NJBob
New Jersey
Mmmm very interesting. Thanks for the info. So you cannot just swap one for the other and call it a day. Sounds like it would be great for a marine application
Dad
Not sure what 'AGM' stand for, but sounds like a possible fix for the deep sleep problem. One obstacle of which I cannot seem to get an answer to is how to get the revised Forscan codes into the Maverick's system.
I'm thinking I'll wait for Ford to address the issue and keep things factory.
Ranch
Sacramento CA
2023 Marverick FX4 4K
The EB Maverick's come with this battery, BHEF-48H6, which is an "Enhanced Flooded Battery." This EFB battery is designed to handle start-stop systems. AGM's can outperform EFB's and can be used to replace them.
Here a link to a BatteriesPlus article that gives a good rundown on this subject.
Can I Replace an EFB Battery with an AGM Battery?
https://www.batteriesplus.com/blog/power/efb-and-agm-batteries
NJBob
NJBob
New Jersey
It stands for advanced glass mat I think. It uses a gel instead of a liquid electrolyte. Need special chargers tho and a charging system in the car geared for it.
Random
Richmond, VA
I thought the Maverick (at least hybrids) have an AGM battery. I’m sure the part number be fired that. Am I wrong?
Ranch
Sacramento CA
Random
Richmond, VA
Dang, wonder what I was thinking. Thanks!
Johnkn
MD
Absorbed Glass Mat
