Wheel set for snow tires
Xcskier
Hayward wi
Maverick hybrid xlt
Maverick XLT hybrid should arrive any day now. I’ll put four Toyo snow tires on for safe driving in NW Wisconsin. Anyone have suggestions for buying an extra set of wheels for these?
AzureBlueBill
Torrington, Connecticut
Tire Rack shows 368 18" wheels for the Maverick, and 37 of those are between $150-$200 each.
NoVaJimmy
KCMO
Lexus GX 460
Just find a set of take off wheels from a Maverick or a Bronco Sport. The steel wheels from the Maverick XL can be found especially cheap. I suggest OfferUp, craigslist, Facebook marketplace
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
You can also keep your eyes open on marketplace for used rims/tires in your area.
You'd be surprised as to how many great deals come and go.
LSchicago
Lloyd
IL
Bought these 18" Bronco Sport take offs with like new Toyo snows for $750 here.
Ford Maverick Wheel set for snow tires 23mav78
RedRider
Kitchener, Ontario, Canada
Just get a set of the right steel wheels. Do not get aluminum rims for use in salt solution, as they will corrode quickly.
If you search around the Pacer 83B 5x108 17x7 steel wheels are about $105/ea shipped + tax.
LKQ (collision parts supplier) lists the XL replacement steel wheels for $91, but I don't know how truly available they are.
siberdraknon
SW MI
2023 XLT Hybrid Cyber Orange
I bought a set of XL steelies from a member here. None were listed locally so I just posted a WTB. A member nearby messaged me and we made a deal. Quick, easy, cheap.
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Same here, but that was over the summer and I'm in Wash D.C. So it was easier to find a MTC seller in this populated area. $500 for steelies with tpms, newish tires and lug nuts. I even gave my sister the tires for her CR-V.
OP doesn't have that same luxury being in the great white boonies in winter. If I were the OP, I'd use the XLT rims this winter and fix it all up in the summer. Wait for that MTC steel wheel deal to come along.
Optimus
MN
2023 XLT Hybrid
I would say this depends on various factors, starting with budget. From there, what are you trying to accomplish with looks/styling? Are you ok with used wheels? If you use Craigslist or Marketplace, you may find something (somewhat) locally. Your town isn’t huge, but if you don’t mind a drive, I would expect to find something around the Cities. Not much to be found up north by the Twin Ports. Otherwise, you can order online via sites like Discount Tire or Tire Rack that have vehicle configurators, and have something shipped. If you are comfortable with looking up and comparing wheel specs, you could buy elsewhere too and piece together your own solution. I bought alloys off eBay based on specs, price, and looks. I also added TPMS sensors separately, though my new ones are not working(!)). You will likely need new lug nuts too, particularly if going aftermarket.
LSchicago
Lloyd
IL
Steel wheels will corrode quicker than Aluminum.
FamousAmos
GAB
Maryland
2022 Maverick Hybrid XL
Check out the postings on THIS FORUM. A lot of owners have replaced their steel wheels. You can probably find a set with minimal mileage on them. Good luck.
RedRider
Not true. They corrode only trivially, and are very easy to clean up again with a wire brush and a paint can. Aluminum on the other hand, is virtually always a writeoff. The cause is that the clorine in the salt liquid on the road eats aluminum way faster than iron. Try somehow cleaning up aluminum rims and you'll be throwing them away.
LSchicago
Lloyd
IL
I've seen many steel wheels with rusted beads that would not hold air. Grinding and painting the beads to try to save a scarce wheel usually doesn't work either.
BTW, I just sold a 25 year old E150 van with 2 sets of aluminum wheels. Both sets were still fine. One set original to the 99, the other set I mounted snows on were off a 2000 E150.
RedRider
Yup, the liquid tends to collect in the bead area, causing corrosion. That's why tire installers put a swab of liquid rubber goop on the bead to fill in any small leaks.
