What Does Your Engine Sound Like?
Juzo
Gamecube64_1994
Waiting On Maverick
I've noticed that the Maverick's engine is very loud and not in a good way.
all I hear from it constantly is valve noise. Is this just a normal Ford thing? Does your Maverick sound similar?
The oil was changed 3000 miles ago and is changed every 3-4000 miles.
JibbersCrabst
Arkansas
2013 Focus ST, 2022 Maverick XLT
Ecoboosts sound like a bucket of bolts. Welcome to the family. :LOL:
commadorebob
Could be the side effect of quieter engines. We can hear the valves where before they would be drowned out. But I work with computers, not engines.
It sounds similar to my I-3 EB Escape. Seems to run fine.
Saul T Knutz
Coastal Virginia
2006 Crown Victoria
I'm just a casual dummy, but it's probably normal. Quite a few videos of normal Ecos with the hood up, compare it to yours. If it's the same, you can quiet it down some with an engine cover from the Escape or Focus (iirc), and add perhaps add some material to the underside of the hood (I forget what the name is called, but it's that fancy felt stuff some cars have)
fossil
ernie
ohio
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
yep the fuel injectors ecoboost have all the same "sewing machine" sound across the forum
Bad Actor
Christopher
SE Missouri
01 Ranger XLT, 73 Mustang Base, 02 Toyota Camry
The valve noise you hear is actually the high pressure fuel pump.
Decayed
yes
a car
Sure its the valves? Could be the injectors.
This. The injectors on these engines are noisy. Sounds like a loud sewing machine. If they could figure out how to make 4 cylinders growl it would be great.
It's not the valves.
Sleeper 7
Steven
NH
18 Fusion 14 Ram Dump 23 Maverick XL
As mentioned above its the high pressure fuel pump. Just tell your friends its a diesel.
