What Does Your Engine Sound Like?
al4tay
Al
Valley Stream ny
Maverick XL
Definitely not normal
My ‘22 XL awd with turbo is quiet
Braderick
Brad
High Point, NC
Bolt EV, RAV4 Prime, KИ EV6
Powered by Edward Scissorhands.
uze uh bag a leafs ta ensalate ya injen…
IronHammer
SW Indiana
Velocity Blue XLT (no lux) FX4, 4K
My EB sounds like a cross between a sewing machine and a moped but I love the MPG’s and it looks good sewing down the road!
Nw_adventure
Salt Lake city
It's interesting - I find that the XLTs built in late 2021 were much louder than for instance my 5/23/22 build date FX4/Lariat -
Big Kahuna
WA
It sounds like the paint shakers at Home Depot.
LM42
Luke
Phoenix, AZ
Maverick XLT FX4 EB
As noted by others, you are hearing the fuel pump and injectors. Most car companies are using their own variation of a 2.0 direct injected turbo, and I have yet to see one that is actually quiet. This is totally normal
NoVaJimmy
KCMO
Lexus GX 460
The valve noise you hear is actually the high pressure fuel pump.
This is the correct answer. The high pressure fuel pump makes it sound like a diesel. This is unfortunately a cheap vehicle and there's virtually no sound deadening material used on any trim level. Thankfully it's not too expensive or too difficult to install yourself if it really bugs you.
Big Kahuna
WA
This is about as close as I can describe :) It's actually pretty accurate.
RR - All the way
GA
Really? Time for a major tune up. Of course, I drive mine in Eco most of the time. Does noise levels change much with transmission mode????
I presume acoustic windshield matter little??????
NoVaJimmy
KCMO
Lexus GX 460
From my understanding the acoustic windshield is there more for the B&O sound system and probably to help mitigate wind noise. Since engine noise is coming through the firewall and not the windshield I doubt the acoustic glass is doing anything at all to help address the engine noise.
Also, the modes do much more than alter transmission shift points. They change the throttle mapping and I'm sure to some extent ignition timing and possibly on the ecoboost models the electronically actuated wastegate. I doubt the modes have any affect on noise.
In my lariat I have a hard time hearing engine except when at less than 5-8 mph.
Big Kahuna
WA
They asked what the engine sounds like - open the hood and listen, it seriously sounds like paint shakers :) Not too noticable when driving but the ecoboost engines sound terrible when you're listening to them outside of the car.
