Unexpected - Can't use my Harbor Freight ramps?
Mox4615
Jeremy
NC
2024 Lariat
I use the Pittsburgh brand from harbor freight. Work like a charm, only raises it up about 6 inches but that’s all you need.
That’s what she said 🫡
commadorebob
Harbor Freight is great for weekend warriors. Professionals would obviously need to get higher-grade equipment. But I did see the recent Project Farm video on the ramps and all but one outperformed their ratings with the one looking obviously sketchy. He mentioned lower-riding vehicles would struggle with the ones from Harbor Freight.
Interestingly, I have a pretty deep gutter at the end of my driveway. So, I literally just park at the end of driveway if I need to get underneath the truck. As my video instructor from the military taught me about expensive equipment: things don't fall off the ground...
there are a bunch of specialty low profile ramps.
when shopping those, however, make sure it raises the truck enough to get under there. I know a guy with a miata that bought a set of ramps that he could drive on, sure... but they only raised the car about 2.5". :unsure:
NC_Pinz
NC
2022 Ford Bronco OBX, 1975 Ford Bronco
A couple of wooden blocks is all it takes. For those that have lived with a lowered ride, you may have to do some block stacking to get on your ramps. If you scrape going over speed bumps, you know what I mean.
Guv
Ford
I have some Race Ramps, not cheap but very nice.
710-oil-614
Cal
2025 Hybrid AWD Lariat
I need a ramp to access and leave my back yard, and was previously using some standard Harbor Freight metal ramps. As you can see by the photo below, my 2024 Lariat bumper facia is too low for me to use them now, making contact with the surface of the ramp when the tire is still a couple of inches away. Anyone successfully using another brand of ramps with their Truck?
The forward mud flap looks like it will make contact too, but I'm less worried about that as I can remove it if I have to.
that’s how you get such good mileage. Honestly the “chin” is flexible and you will not damage it much (Ford plastic is softer than triple ply charmin) by driving up the ramps. You’re going to beat that chin up in time anyway so go ahead and do it.
dochawk
doc
Las Vegas
I use Harbor freight for "disposable" tools; such as those that are less than two rentals at Home Depot, our naturally get worn through.
But whether I Harbor freight or something else, I can't bring myself to crawl under a couple of tons of steel supported only by plastic!
inline_five
2023 Hybrid XLT
Plastic actually well outperforms metal in car ramp use.
Blinky
Alberta, Canada
I had a pair of those baby ramps for my Fiesta ST, it was low enough from factory that I needed them to get a jack under the car. I eventually bought a $400 long reach low profile jack that worked like a charm.
JimKivi
N Calif
2023 Maverick XLT 4x4, Silverado, Mazda 3, Ranger
On my ramps, a foot long piece of 2x6 under the end of each ramp allows the tire to climb up on the wood, then the ramp with the angel just enough changed to clear the bumper.
commadorebob
In testing, the plastic ones performed well. A block of plastic send the forces directly into the ground. In a few cases, the plastic ones exceeded the capacity of his test rig that can get up to 30 tons.
flyswatter
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
I can attest that my metal ones dig quite badly into the ground at the front. For what it's worth.
flyswatter
flyswatter
Macon GA
Thank you! Although others have very kindly replied with similar advice, your particular specificity really helps.
Lobstah
Orland, Me
2024 Maverick XLT, 2020 Volvo XC90
Seriously?...put a piece of 2X4, maybe 1ft long in front of the ramp.
