Unexpected - Can't use my Harbor Freight ramps?
The Real Maverick
Jack
CAUTION:
Gotta be careful with modifying or "Jerry rigging" equipment in a life or death situation.
Also, need to consider your environment. Metal ramps on dirt should be a no go. Pavement use only.
Maverickman74
Shane
Maui HI
Got a set of those plastic parts store ramps. Had em since 2010 and used em for Econolines and other heavy stuff. Their slope is a lil straighter.
Rivers90
Ben
XLT Tremor, Miata
Use wood : 2x8. 2x10 something like that. Just stack layers flat like mini 1.5" stairs.
I see that the Rhino Ramps are listed as 17 degrees, here's a handy calculator to help you determine what angle ramp you need;
https://www.raceramps.com/angle-of-...vSGHZjDB4mS_rgqTqo5kERW0ntjg-oBXuDWJPiA7xyzya
HRG
How much ground clearance is there under the nose of a Lariat? Does the XLT have the same?
I need a ramp to access and leave my back yard, and was previously using some standard Harbor Freight metal ramps. As you can see by the photo below, my 2024 Lariat bumper facia is too low for me to use them
The forward mud flap looks like it will make contact too, but I'm less worried about that as I can remove it if I have to.
How much ground clearance under the forward mud flap?
I have a Tremor so it looks nothing like this.
flyswatter
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
MiMav
'23 EB FX4 4k Maverick, '14 Escape
I have the same problem with my ramps. I had just assumed there wouldn't be an issue since my '09 Flex and '14 Escape are both fine with the ramps and they are front wheel drive models. My FX4 with theoretically higher ground clearance has a lower approach angle.
OXHB619
Clayton
XL EB 2.0
another vote for the plastic harbor freight ones from me. I used those with my last vehicle without issue and it had pretty low clearance ( 2003 Toyota Matrix ).
JBL14
Co
Old cars
FYI project farm just recently did a ramp test and 5e results were pretty surprising. IIRC the HF plastic ramps performed well above their design limits.
After watching the video, I am glad I made some simple wooden ramps out of stacks 2x8s. I won't waste my money on any of them.
Vickram
Dearborn Michigan
Blk 23 Mav Lariat , 09 Escape ,72 honda 350 cycle
I need a ramp to access and leave my back yard, and was previously using some standard Harbor Freight metal ramps. As you can see by the photo below, my 2024 Lariat bumper facia is too low for me to use them now, making contact with the surface of the ramp when the tire is still a couple of inches away. Anyone successfully using another brand of ramps with their Truck?
Based on your picture , if you add a 2" X 10" X 12" to 15" long place them in front of your tire and up the ramp a bit That will do the trick . . ADD a screw through the wood and into the metal ramp to keep it from slipping down , one in each ramp is enough . Under $15.00 at Menards .
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
You are going to rake them over a tire stop sooner or later, or a curb, it's a truck, treat it so.
flyswatter
flyswatter
Macon GA
Fair enough, but I'm not worried about scratching something; I'm worried about damaging or tearing it off from an avoidable potential abuse.
dochawk
doc
Las Vegas
Plastic actually well outperforms metal in car ramp use.
measurements and statistics are one thing; trusting them while underneath a couple of tons of elevated steel is another . . .
dochawk
doc
Las Vegas
also, it would be tough to get the image out of the semi-collapsed plastic one I already have out of my mind!
I don't remember whether it slid as a vehicle went up, or missed, or whatever, but . . .
