Towing with Maverick Hybrid
Scupking
2025 Ford Maverick XLT Hybrid
Tow limit is not low if you get a 25 or newer with AWD and 4k tow package. I tow a jayco jay flight slx 170bh. 3000lbs empty with 300lb tongue weight.
Montykeel
Monty
Rogers AR
2011Escape Hybrid and 2022 XL Poverty Edition
Sorry I left out that detail. XL hybrid with factory hitch. 2k towing capacity. Never weighed it but total payload had to be way under that
Maverick123
Waiting
... One note: put a cloth or sponge over the handle on the trailer tongue when you lower the tailgate or it will dent the tailgate (ask me how I know.)
That's why you ALWAYS put the tailgate cables in the upper position when towing. It's the first thing I do even before installing the receiver
That's a great suggestion.
Thank you. 🤝
notfast
Los Angeles CA
and dealers get fewer false alarm complaint's from drivers.
Reminds me of how earlier D40 Nissan Frontiers had a real oil pressure gauge in the instrument cluster. Due in part to the constant fluctuation of the gauge (but within the normal operating range) that caused a lot of unfounded warranty time, it was subsequently replaced with a "gauge" that has 3 needle positions: no pressure, acceptable pressure, over pressure.
Yes Place your water containers in front of the rear whells, about 300 Poundsand have the 5th hitch over the wheels. There is room.
I believe the point that @Mavster Mechanic was trying to make is that the rear wheel wells are integrated into the front wall of the bed. Therefore to put anything in front of the rear wheels would mean it'd have to be on the back seat, or in the foot or so of space that is forward of the center of the rear axle but still in the bed.
Either way I don't see the Scamp 5th wheel hitch being a possibility. The cab-to-rear-axle length is extremely short as mentioned, so it'd limit how tight you could turn. Not to mention that the unibody structure might interfere with where the hitch holes need to be drilled into the bed floor.
I wouldn't tow anything regularly. Not only the mileage issue but the smaller gas engine has to work harder than it was designed to work.
Seeing as the vehicle is factory-rated to tow 2-4k, I'd say that the engine is well within its design parameters. It might need to rev higher and it'd be helpful to drive with a bit more consideration for ambient air temperature and long hills, but the Maverick is certainly no Prius with a hitch (which isn't rated to tow at all).
ulyssesvt
Bennington, VT USA
2025 Maverick AWD Hybrid
Great advice, and had I heard it earlier it would have saved me a small dent. Live and learn.
Mavster Mechanic
Hybrid
Is one weekend a month regularly?
Yes it is. It is at regular intervals.
Perhaps you meant to say you would't tow continuously.
Mavster Mechanic
Hybrid
Yes Place your water containers in front of the rear wells, about 300 Poundsand have the 5th hitch over the wheels. There is room.
I understand what you are trying to say.
Putting water jugs above the rear axle is possible.
To put water jugs "in front of the wheel wells" means putting them into the passenger compartment.
Ford Maverick Towing with Maverick Hybrid 1782061467076-x7
Mavster Mechanic
Hybrid
exactly. The Maverick is best used as something to haul a tent in for camping.
says someone who does't pull a big trailer with his so 🤷🏻‍♂️
Mavster Mechanic
Hybrid
I have a ball hitch that does not interfere with the down tailgate. But MOST will.
grandpopa'sMPGs
Cincinnati, Ohio
Ford Maverick, Chevy Cruze
if it is just 2 of you then putting water jugs on the rear seat floor is even better. Pack the rear seat with heavy items helps. More weight in the truck give more control.
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
As a bonus, the backup camera is now pointed right at the hitch, to help with lining up the ball.
Flyangler
Sarah
Minnesota
2022 Ford Maverick Hybrid XL
One of my boat/trailer combos is about a thousand pounds, the other is around 665, most of that being the trailer.
If I had anywhere to store it, I would consider a teardrop style camping trailer. In the summer my boats take up the whole back driveway. I don’t want to make the place look all junk yard with an additional trailer I would have to park in the yard.
Shock96
Olympia, WA
2025 Maverick Lariat Hybrid AWD
Last August I loaded up a U-Haul trailer (6x12) which has a unloaded weight of 1920lbs.
It was mostly filled with stuff. Clothing, furniture, books, craft stuff etc. I would estimate about 1600lbs of stuff give or take.
I drove it from Portland Oregon down to the greater San Diego area for my sister-in-law who moved in with her son after my brother-in-law passed away.
Towed really well. It was close to max weight so I wasn't driving super fast. I kept it to 60-65mph most of the way and was at about 55 up the passes and Grapevine. No overheating, no weird smells. Worked great!
Some folks say that they were doing 70mph up 6% grades towing 4k pounds and I just don't think that is true. Yes the Maverick is a tough little truck but 4k is a lot of weight for the Maverick. It works but I wouldn't want to do it daily.
Mine is a 2025 AWD Hybrid.
Ford Maverick Towing with Maverick Hybrid Towing
Ranko Kohime
Ranko
2025 Maverick XLT
Just curious what are y’all towing with your Hybrid Mavericks since the towing limit is so low?
Hello, 2025 FWD Hybrid here, this boat weighs 6,300 on the trailer. No issues until I was trying to go uphill on straight ice when a car slowed me down, lost enough traction to come to a gentle stop.
Ford Maverick Towing with Maverick Hybrid IMG_0330
