Towing - Loose hitch in receiver on 4k tow package.
Ksprelude01
Keith
St louis. Mo
2022 Ford Maverick Lariat FX4
I've towed a few times now with the Maverick and I'm getting concerned with the looseness of the hitch in the receiver. I've tried 3 different ball hitches in the receiver but each have a little play witch causes honorable banging noises each time you brake or accelerate. It became very pronounced when i tried pulling my Jay feather 23B 3800lb camper for the first time this weekend. I don't know if I should try and find some metal shims to remove the little play in the receiver or that's just how it is. I still have to try the weight distributing hitch still for the camper but I have to readjust the height of the ball on the hitch from when I had it on my old f350. Just want to see if anyone else has this problem.
Ford Maverick Towing - Loose hitch in receiver on 4k tow package. 20250302_130700
ThisWas
NH
2022 Maverick Hybrid, 2021 RAV4 Hybrid
I had a little rattle when braking while towing a small sailboat so I added an Anti Rattle Stabilizer.
Ford Maverick Towing - Loose hitch in receiver on 4k tow package. t1
Ksprelude01
Ksprelude01
Keith
St louis. Mo
Thats the design I was looking at getting. Its cheap enough to give it a try at least.
matmondro
Mathieu
Vassar, MI
Yes, my 4k tow truck does have a little bit of slop in the receiver. It hasn't bothered me too much, but I too can confirm the slop is present.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Most receivers are going to have some play and that’s an excellent way to get rid of it.
Definitely not a Maverick or Ford specific issue.
Johnny maverick
Nh
I noticed that the unibody telegraphs noise way more than a full framed vehicle. Drove me nuts the first time towing. I put some black tape around the hitch and turned up the radio. :)
dhaskit
Dann
2024 Maverick FX4 Lariat
That is the case on every vehicle that I have owned with a receiver hitch and it is certainly annoying, but benign.
I wrap a line of plumbing repair tape both forward of and behind the cross pin of the hitch and it reduces the clunk. Plumbing repair tape is pretty stretchy and works better than electrical tape.
Ford Maverick Towing - Loose hitch in receiver on 4k tow package. Screen Shot 2025-03-03 at 7.42.05 AM
Gray Goose
RG
Wissota
Also, make sure the correct hitch pin size is being used. There are both 1/2" and 5/8" pins. Using a 1/2" when 5/8" is needed will cause the banging described. The pin should be tight fit. There might be little rattle, but never a banging.
Tim d
Alpena
Ram
O
Its normal.
lm126027
Larry
Central MA
2024 EB
It's a Ford thing.... Both my 2010 & 2015 Edges, my 2020 Escape and now my 2024 Mav have all had that rattle. You get used to it after a while. hahahaha
nandesho
Houston, TX
‘23 Hybrid Lariat BAP, '24 Hybrid XL
I suggest using a weight distribution hitch if you're towing a travel trailer. Improves ride and handling characteristics while removing any slop.
For lighter trailers the anti-rattle clips work great.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
My bike rack and ball hitches all rattle a little, kind of the norm. Like others suggested I use an anti-rattle device and it works well.
Go and check just about any vehicle with a trailer hitched up, a lot of them will have have some play on the ball mount. Some people aren't bothered by it, and others are.
icegradner
It's not a good idea to use a weight distribution hitch on a unibody vehicle like the Maverick.
https://www.etrailer.com/question-241876.html
