Speedo reading 2 mph higher than GPS
playinboats
Kenneth
2022 ford maverick
Wondering if others found this. Tires are Firestone all season 225/65R17
DS_Ohio
SW Ohio
2024 Ford Maverick XL Hybrid
The Japanese motorcycles I've owned are closer to 10% optimistic. The Maverick is not nearly as bad, based upon my cellphone's nav readout of current speed.
MaverickDragon
Grand Canyon, AZ
As noted, few (if any) cars have a completely accurate speed readout unless they are calibrated.
Just a minor change in tire size, even due to wear, can alter the accuracy of the displayed speed.
IIRC, Forscan can be used to change the speedometer reading so it's spot on, otherwise an exactly accurate speedometer is unlikely.
Wouldn't tire wear affect a calibrated speedometer?
Is it recalibrated it every couple thousand miles?
MaverickDragon
Grand Canyon, AZ
The variation due to tire wear is part of the reason why police departments have a regular schedule for street patrol vehicles that use pacing for issuing speed tickets.
Anything that changes the circumference of the wheel/tire will affect it, including tire inflation pressure.
tiktokbrainrot
around
91 F250, 20 GLI, 25 Mav XLT
All cars will read slightly faster. The reason is that, if a car is found to be underreporting speed, the car manufacturer can be held liable for speeding tickets.
The speed calibration is set when tires are new, so any amount of wear will slowly throw the number off.
Yes, which is why calibrated certification is expensive, and on police cruisers, their speed radars are calibrated daily to ensure accuracy. They also have GPS data backups to ensure accuracy.
In my experience, my german cars have been right on the money when new, and 1 MPH optimistic with tire wear. My 91 ford is WAY optimistic, I think something is up there, its 5-6 mph optimistic, and my work Maverick is right alongside the germans at 1 on new tires.
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
I usually see ~1MPH difference in unmodified vehicles. More, if wheels or tire sizes have been changed without recalibrating.
MaverickDragon
Grand Canyon, AZ
Can be held liable? Highly unlikely, as many factors outside of their control impacts that.
Federal law allows factory speedometers to read up to 5% higher or lower than actual speed at 50mph. If outside that range, a judge isn't going to issue a ticket to Ford, but an attorney might seek damages, typically in a class action, such as one that Honda settled.
Since most speedometers err on reporting a lower speed, it's a lot more likely that the error would be on the driver, typically for adding larger tires or wheels.
Back when phones were getting GPS receivers, and prior with actual GPS device - all 6 vehicles since then have shown under actual speed by that amount.
Even the Maverick has like 4 PIDs a scanner can get to regarding speed - and the one for use by the IPC is lower than the others.
It actually appears the system gets metric measurements and convert to miles - because my 65 mph reading on cruise control easily is 64 on the gauge speedo as it is clearly not halfway, as is the PID for speed, 64.3 or such.
I'm sure it's a rounding error from metric.
lavaspill
Jeff
Buy some larger tires, that will straighten that problem right up.
not null
"Upstate" NY
Hybrid Mav
Yeah.
My snow tires are the same measurements as my all seasons.
With the snows, the speedo reads 2mph faster than gps.
With the all seasons, the speedo and gps basically match.
Mudduck
JD
Utah
Mine was 2mph off. I used FORScan and then my COBB to adjust. Now My Speedo/GPS/Wolf-box dash cam all match. When passing by the speed indicators, or construction signs they'll flash 69-70(for example) back and forth. seems like I'm .5 MPH off. I can live with that. It will change as the tires wear I'm sure.
