- First Name
- Rough
- Jan 9, 2022
- Torrance, CA 90503
- Down to just the Mav
- Engine
- 2.5L Hybrid
Since the Maverick has a new-to-me approach to stowing the spare tire, I thought I would do a dry run on its use in my driveway on a nice, sunny afternoon. After all, why not play with my toys for an hour and also reduce future swearing, at night, in the rain, on the side of the interstate? I strongly recommend that you do the same, since you may discover some things sure to make your future life easier and safer. Here's my list of personal epiphanies:
1. IMPORTANT: The tailgate MUST be up for the jack handle extension tube to fit thru the hole above the bumper and lower the spare. If you have a jack extension drive tube in place and lower the tailgate, you may damage the tailgate. (Don't ask how I know this.) If you get a flat while carrying a full load that covers the tailgate, you're screwed. An attached trailer will also interfere with your ability to turn the handle and lower the spare. All these problems could have been solved by putting the access hole in the wheel well or on a corner instead of centered above the bumper. Great job, Ford!
2. Study how the jack is packed when you unwrap it so you can get it back the same way. The manual has sketches on p.357 & 360. The small plastic tip seems useful for removing XL hubcaps but n/a for alloy wheels.
3. The gender of the jack extension tubes may seem backwards to anyone used to square drive tools. e.g. The female end goes into the truck, and the male end engages a square hole in the handle.
4. You will probably have to lie down on the ground to be able to reach under the bumper well enough to disconnect the spare from the cable system. I suggest you keep a small (5x7) Harbor Freight tarp with the jack. Some heavy nitrile gloves wouldn't hurt either, to keep your steering wheel clean on the rest of your trip.
5. There's a heavy redundant cable (in addition to the winch) on the spare. I assume this is to prevent injury to the person tailgating you, should your winch cable fail.
6. There's a blue plastic cone that must be removed from the cable to get the spare off. This item is at VERY high risk of loss on the roadside, so try to put it back on the cable as soon as you disconnect the spare, and of course, winch the cable back up so it won't drag on the ground.
7. If you have aftermarket lug nut locks like McGard, consider putting the key where you're sure to find it even if you forgot where you put it several years from now. You DID already order a spare, right?
8. I don't carry wheel chocks, but I do carry ratchet straps that tie up tightly for storage and could be used for that in a pinch.
I'm sure other members will chime in and share the wisdom. Please do!
Edit: Thanks everyone so much for all the really good suggestions on lighting (flashlights, magnetic 12V LED work lights), better tooling (compressor, plug kit, socket & ratchet), and hygiene (disposable attire, large trash bags to cover failed tire, etc).
