Solar panel mod for Hybrid Maverick?
mamboman777
Josh
NRH, TX
Would it be crazy to install one of these permanently to the 12v battery? Wouldn't be that hard. Mount all hardware behind back seat, run cable to bed or roof. Could probably just use some good magnets to keep solar panel from sliding around. Could this work? What would the downsides or risks be?
pndwind
Heart of Dixie
F450 Amb
What’s the end goal for this? I’m just trying to understand what is the benefit you’re looking for.
mamboman777
mamboman777
Josh
NRH, TX
Efficiency. Making sure that the 12v is good to go. Avoiding the deep sleep when it sits for a while.
Maleldil
Bruce
Virginia
Hybrid Maverick, Transit Connect
Don’t recommend things sitting for a while.
But that seems like a bit extra hassle than having a emergency jump kit on standby. More uses for the jump kit than the solar panel. More concern would be with the high voltage battery and it sitting for a while. Even with the 12v topped off would have to wait for the HV battery to charge to get your mileage back If the HV drained while sitting.
Adeveda
Adev
Atlanta, GA
2010 Literal Garbage (AWD)
I've long wondered why no one has invested more to spearhead a solar-sipping passive trickle charge to supplement a traditional EV drivetrain. Who cares if its inefficient if you make it known through marketing that its just supplementary? I wouldn't be mad if I only reclaimed 15-20 miles worth of charge while my car sat in the parking lot at at work. That's a free commute home.
The sun has literally never sent me a bill.
RockCity
Detroit, MI
Ford Escape Hybrid, F250
Odd way to frame it. If it is inefficient, why would you want it? You will lose more in drag than you will gain in solar. You maybe have never recieved a bill from the department of wind resistance, but trust me, they have charged you.
es7129
Ed
Long Island
There’s a company that makes hard tri-folds with solar panels embedded.
If you can get it to work if imagine it would be useful as Hyundai has integrated solar panels into the roof of the Sonata hybrid.
Adeveda
Adev
Atlanta, GA
That's a great counterpoint. There is definitely a breakeven point where efficiency and wind resistance trade off. I'm inclined to believe that breakeven can be adjusted handsomely depending on placement/implementation. I think the drag argument as stated overlooks a manfacturer's ability to install a panel seamlessly into the body.
For instance, I don't think it's a stretch to instal a solar panel in place of the moonroof.
TyPope
Ty
Papillion, Nebraska
2020 Tesla Model Y, 2018 Ford F150
Elon seems to think that by making the bed cover on the Cybertruck solar, they could add up to 20 miles of range a day.
Adeveda
Adev
Atlanta, GA
Further, trickle charging is healthier for the longevity of a battery.
Adeveda
Adev
Atlanta, GA
I have an instinctual hesitation to putting glass on/in/around the truck bed, including the cover. I want to use my truck like the tool its designed to be, and glass is brittle. Even sapphire - that's just scratch resistant. It would still crack, chip, etc. I'm less likely to rest a toolbox or whatever on the roof of my truck than i would onto a bed cover.
Decayed
yes
a car
There is a thread where someone did this. Electrically what he did was the equivalent of plugging a jackery solar generator into the 12v outlet. It will work but it all depends on the charge controller. IIRC if the key was in it the ICE would kick on if the load drained the 12v battery too much.
FYI you can get flexible solar panels that are very flat. I got a kit on ebay for my old car that is designed to keep your 12v battery topped off. It plugs into the 12v outlet. You stick the panel on the dash or wherever it gets the most sun and plug it in. the 12v in the mav switch off after 20 min so you may need to rewire something. My old car had an "always on" 12v outlet that was perfect for it.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Fisker cars had that. Panels built into the curved roof. Very good looking cars, they never got the marketing hype of Tesla, and were expensive.
jsus
2022 Ford Escape Hybrid AWD
