Aftermarket Exhaust for Hybrid Maverick?
stevj
Stev
Pacific Northwest
2024 Hybrid Maverick
Try THIS for more horsepower. It should work for any engine.
wax87
Stuart
Dallas South
2004 Avalon
This is America, even hybrid owners have the right to annoy their neighbor at 6am with the sound of a 3,700lb fart noise generator.
Damm Right, and I am hoping to live next to you some day
PNWMaverick
Pacific Northwest
2022 Maverick Hybrid - RIP
You can do anything you want to it with the right custom work.
But, just because you could, doesn't mean you should. At least when it comes to a hybrid of this type.
cyberdog
Ray
2023 Maverick Lariat Hybrid
Not sure I'd like a loud version of an Atkins Cycle engine droning into the cabin. The Atkins Cycle already looses power density, torque, and effective cylinder pressure. Adding a low restriction exhaust may further reduce torque, especially at low rpms, and increase the torque peak rpms, without actually increasing torque. That said, Ford dropped the second muffler/resonator on the '23 models, even on the Hybrids, but no word if the primary muffler in front of the rear axle was changed in the process.
I've done aftermarket exhausts in the past, and many times you do loose low-end torque, in exchange for a few measly horses at higher rpms. Granted the traction motor's roughly 137 ft/lb would help negate the torque loss, but it may sound ugly with the extend valve timing. I suspect you may also need a tune, to work around the change in torque/power peak rpms which will may result.
If you actually end up doing it, I think I can safely say we'd all be curious to hear a realistic sound clip from both inside & outside the truck.
