Power Inverter location?
EMD_Driver
South Carolina
2015 F-350 DRW 6.7 / 2022 Maverick XLT 2.0 AWD
I wonder if it would be safe to replace the console USB fuse with a 10A or 15A and use a USB to barrel plug adapter to power your laptop. You don't actually need an inverter just to use an AC adapter to convert back to DC. AFAIK the rear console USB has a 5A fuse behind it and the front ports wire directly to the infotainment system.
If I remember correctly, most laptops require 19VDC and a USB only gives 5VDC. Unless you can step up the voltage, it will not work.
It is much easier to get a cheap inverter to go from DC to AC and then just use the laptop's factory power adapter.
TacoHolder
Phoenix AZ
Not Mav
You're right. Most laptops with barrel plug charging require 19.5V input. Maybe the best solution for laptops is to use a 19.5V charger that plugs into the 12V accessory socket.
oilman300
Georgia
2022 Velocity Blue XL Hybrid
Second pic, what is the silver box with the cooling fins? Is that the inverter or the B&O amplifier? It's kind of big for a 400 watt inverter.
It's the B&O amp.
cannon
mark
oregon
2022 Maverick XL awd
Has anyone verified the location of the actual inverter and not just the outlets?
I am a ford parts guy, our catalogs aren't totally reliable and there is a lot missing (I can't even look up an oil filter yet) but show the inverter in the center console, part # N1PZ19G317A
EMD_Driver
South Carolina
Thank you sir!
Moby
Fort Erie
Hummer H3 sprinter van 65 chevy 11 Doka syncro
I have a question related to this . I ordered an XL with 400 W inverter , will there be a 110 in he the truck bed or just in the armrest ? thanks
wyouger
Williard
2011 Ranger
Just the rear of the center console
wyouger
Williard
2011 Ranger
I am not doubting this information. Just checking. A Google search for N1PZ19G317A shows. "Cover - Low Air Pressure Sende - Ford (N1PZ-19G317-A)"
cannon
mark
oregon
Ford's parts descriptions are complete nonsense half the time and getting worse every year. A few days ago I quoted a taillamp assy with the description "Bulb-exterior"(... the bulbs aren't even included with the lamp assembly).
Allen King Jr
Allen
Springfield Missouri
2019 Grand Caravan GT, 2006 Mercury Mariner
Probably already answered, the finned aluminum box is the amplifier
Decayed
yes
a car
Decayed
yes
a car
huunvubu
coppell tx
2023 Ford Maverick Hybrid
The Inverter is NOT behind the Rear Seat.
My Hybrid Maverick has the 110V/400W option with the Outlet in the Cab.
The following are pictures behind the seat and of the outlet.
There are no modules mounted behind the rear seat so the inverter is somewhere else.
Ford Maverick Power Inverter location? Outlet
