MIL on/P0302 Misfire - 2025 Maverick 2.0 EB
Chops
Lobo
Sorry. No way you should have to run gas above 87 octane. You get a truck with engine that should give you better mileage and save money then pay more for high octane “top tier” gas.
I’m guessing a modified exhaust is more likely a problem. I don’t go on othe vehicle forums but seems like a lot of Mav owners seem to think they must immediately do everything they can to improve performance. Why? If your little truck isn’t powerful enough for you taste get a truck the comes stock with better performance.
Top Tier Gas is not for performance - it is for cleanliness. The detergents in Top Tier will help keep your fuel system cleaner - especially the all important injectors.
Do you wash your clothes to run faster? Nope - You wash them so you don’t stink. (No offense if you don’t use clothes detergent either…plain water will work just fine actually).
Cancunbadlands
Cancun
Cancun
Marty
2026 Ford Maverick Tremor
No, not a word. He did ask if I "had tuned it." Nothing about the exhaust system.
They wouldn’t need to ask, they’d know soon after they hooked up to your truck.
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
Yes, I agree with you that an exhaust leak could cause a lean condition, if the fuel system couldn't compensate enough. However, the exhaust system I have is a post cat type system. It's been on the vehicle since almost new (700mi) and I've not had any issues up till now.
Also, I would have thought that any fueling condition, rich or lean, that would be severe enough to melt plugs, etc would have triggered a bunch of fault codes? In Toyota EFI systems, anytime Long Fuel Trim went + or - greater than 20%, it would light up the MIL/CEL. Ford might be different...but, I thought the basic parameters needed to be met by all manufacturers?
As for the valves, rings, pistons, etc. Well, yeah I would be concerned about this also...I guess we'll see?
IMO, If I were You I would have a compression check done on all the cylinders and see if 2 and 4 are lower than 1 and 3!!
Marty
At’ud be a good start, then scope the cylinders.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Chops
Lobo
john21161
john21161
Maryland, USA
2025 Maverick 2.0
UPDATE: April 28, 2026 approx. 16200 miles
AS of today, the truck has been operating normally and no re-occurrence of any of my previous driveabilty/MIL issues.
However, I stumbled onto something interesting today, when I updated my AllData account and added my 2025 Maverick AWD-EB: I found a TSB from FORD. Something called a "Harvest Program" 25H03 looking for spark plugs from various 2025 Eco-Boost vehicles, including the Maverick. The effected production dates for Mavericks are 4/11/25 to 5/27/25. (My vehicle was produced the week of 4/21.) The Harvest Program ran from 8/28/25 to 2/28/26.
The reason given:
"Ford Product Development (PD) is conducting a harvest program among selected vehicles to examine spark plugs on engines with high levels of pre-ignition. Using connected vehicle data, PD will select up to 500 vehicles exhibiting this condition. The customers will be contacted via an owner letter and requested to visit their dealer for a spark plug replacement. They may, or may not, have a Malfunction Indicator Lamp (MIL) and may not exhibit any outward misfire or drivability concerns. Replacing the specified spark plug may prevent future Diagnostic Trouble Codes (DTCs) and possible engine damage."
I'm not familiar with FMC technical/warranty jargon, so I'm guessing here...but, it sounds like Ford was looking for failed spark plugs from "engines with high levels of pre-ignition," that exhibited driveability issues and check engine lights. It doesn't say whether the plugs or the engine tuning is responsible for the failures...but, high levels of pre-ignition doesn't sound good. However, the fact that they only replaced the spark plugs on a certain number of engines produced during a certain time, leads me to believe that they had reason to suspect the issue lay with the spark plugs and not with the EB engine or it's programing.
Other than this, I've got no new info. I'm hoping that a bad batch of plugs was the root cause of my original problems. We'll just leave it there. The effected number of 2025 trucks is relatively small and farely early in production. If your Maverick was made before 4/10 or after 5/28, you're probably ok.
I'll update, if anything new come up. Thanks.
BLUEOVALRACER
Ravenna,Ohio
The reason given:
Thanks for the information!! Good to hear Your Maverick is operating normally again!! My Maverick was built in Jan of 2025
Cancunbadlands
Cancun
Cancun
My local Ford Dealer recommended and ordered my Borla X-Type catback for me. They were not honoring a 20% Ford discount on the Ford Performance Exhaust & suggested the less expensive Borla. Anyway, I picked it up at the dealer & installed myself.
Ford does not care what you install behind the CATS…they don’t even offer any type of warranty coverage on their OEM pipes behind the CATS.
Good to know!
Quest
The reason given:
Their getting a higher % of warranty claims with spark plug issues in those date ranges & are fishing for more data
As they get more data the date ranges may be expanded & a TSB may be issued
mavericktwc
Thad
Idaho
2026 Ford Maverick XLT
Although mine is a hybrid - had the same issue 699 miles (2026) 🙄 - 716 miles by the time I limped it back to the dealership- so bummed
U
update… coil failure. Issue is resolved a little unsettling as there are 3 more 🤣
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
Gosh. I definitely wouldn't expect to be doing plugs and packs at <1k miles!
Love the color, btw.
