- First Name
- Kevin
- Aug 16, 2024
- Bulverde, TX
- 2024 Maverick
- Engine
- 2.5L Hybrid
I put on new tires yesterday and put the best of the OEM 225/65/17 Continentals onto the wheel of the compact spare. It sort of fits - teeth are touching. I also have factory hitch, which limits forward placement. I have snugged up the cable to make sure there is not any back and forth movement while driving.
Is there any reason not to deflate that spare some until I need it? (being sure to keep a portable compressor with me at all times…). I don’t want to cut or bend those teeth in case of actual rear-end incident and insurance concerns.
Rivian keeps a deflated compact spare in the cargo area of its new R2, so seems like it should be OK. As long as you can inflate to correct psi before putting it on the ground.
