In EV Coach, what does the blue box mean when in hybrid mode?
Padre
Fr. Paul
Twin Cities
2023 Maverick XLT w/ Lux, CP360
I imagine it has something to do with the battery, but does anyone know what exactly it symbolizes?
Rod
Rod
Indiana
I think its mostly meaningless..Kind of a ohhh and ahhhh thing. The manual doesnt explain it. Others have tried to explain it but you can tell theyre just blowing hot air,,,
fordmav
Redmond
NA
I have no information to back this up, but given that the blue box overlaid on the white hybrid bar shrinks as you drive, I think it represents the battery power being used in addition to the gas (to help with power and acceleration). Just a guess though.
When the ICE is running in hybrid mode it means that 1) EV mode is available (battery is sufficiently charged) and 2) reducing the throttle to approximately that amount will transition to EV mode. Although sometimes you don't entirely need to reduce throttle to that point; a rapid decrease in throttle input may also trigger it switching over or if the drive-power load low enough at lower speeds it may switch on its own. In EV mode it represents the throttle position at which the ICE will start.
GPSMan
Many
DesertSweat
Arizona
Ford Maverick Lariat, Honda HR-V 6spd
In battery only mode, it's pretty easy as it's essentially the available charge and load ability before transitioning to hybrid.
In hybrid mode, I don't have a clue, because when compared to the powerflow on the Sync screen there are anomalies for the size of the bar compared to whether the truck is in hybrid mode discharging vs charging. The bar can be non-existent and powerflow will show as discharge mode. But at other times, charging. Same with the reverse.
CuriousGary
Atlanta
Ford C-Max Hybrid
How come we have to guess at this, Ford Motor Company? Where is something in the Users Manual? Where are the videos? Why do you like to keep secrets about this fabulous little truck?
GPSMan
Many
Where's the fun in watching "videos"?
Eagle11
Valley of the Sun
It says Electric when in the Blue box, so that means you are running on battery.
Use the search feature in this forum, since you are new, there are hundreds of threads that will answer your questions
ClemsonU88
NC
I have a hybrid, and I've never seen a blue bar/box. What are y'all talking about?
My mpg will switch to blue "Electric", but that's not the same as a bar or box.
Eagle11
Valley of the Sun
Grasshopper read the manual, there is an EV coach to help you keep the Maverick in Elec mode more often. I found it a waste of time, as I watched the EV coach more than driving. I've owned my Hybrid now for over a year and I have a very good feel for my truck.
Padre
Padre
Fr. Paul
Twin Cities
You need to turn on the EV Coach in the star screen.
CuriousGary
Atlanta
Ford C-Max Hybrid
Oops. Meant to say, why does Ford like to keep secrets about this fabulous little truck.
bwil415
G37
I think he's referring to the blue outline which is overlaid on the white "hybrid" mode bar. I've seen it pop up sometimes, but I don't know what it means specifically either. I assume it's the level of battery power being used in addition to the motor, or the level you would have to drop power to to switch to electric at that moment, but it only appears rarely and not for long. Here is my MS paint version:
Ford Maverick In EV Coach, what does the blue box mean when in hybrid mode? 1682434993689
