EV Coach - No Electric Only
Ozarkbeard
If the HV battery gets too hot and/or you're running the HVAC in rare extreme temps, it's not likely the truck will operate in Electric mode.
SP1966
SP1966
Vegas
2024 Maverick XL Hybrid
I am in vegas and mine did the same yesterday. It was a record 120 degrees so i just assume its just too hot for it to kick in to electric.
That appears to be the issue as this morning it's switching into electric mode as it always did before.
SP1966
SP1966
Vegas
? Still would or wouldn't switch?
Regardless, if the HV battery gets too hot and/or you're running the HVAC in rare extreme temps, it's not likely the truck will operate in Electric mode.
Wouldn't. I type fast, I don't type well! LOL
DarkSideMaverick
Las Vegas
2024 Carb. Gray Hybrid Maverick XLT, Lux, Blk Pkg
I suppose I should also mention that I just got mine two weeks ago with 51 miles on it and I have not added or altered any programming. Completely stock so far.
SP1966
SP1966
Vegas
The MyMavMode shouldn't have any effect on the issue. All it does is signal four button presses, it doesn't change any programming.
