Hybrid mode in reverse?
BigB
Bryan
23 Ford Maverick
This may sound strange but I’ve never owned a hybrid. I’ve heard with most you can drive up to a certain mph in electric mode only but does it do the same in reverse? I’m just wondering if I can back in my garage and pull back out without the gas engine starting to avoid exhaust fumes.
theek
Michael
Ottawa Canada
Honda CR-V, Subaru CrossTrek
No, not true. The electric-only option was available on some non-US Pruises (Priii?) but never in lawyer-heavy North America because of our stupidity.
hondabuster
Andy
Minnesota
Rav hybrid ,tacoma
I have a Rav4 hybrid, and my understanding is ford at one time licenced the tech from toyota. What you are describing will work on my hybrid. For 2020, all vehicles capible of ev operation must have a noise maker when running silent. In summer in MN, i can run in battery mode for about 5 miles.
SuckLemons
Tennessee
2022 Toyota Tacoma 🌮
My current hybrid and my old Ford Escape hybrid worked like under so many miles per hour it would be electric as long as it’s not in sport mode. Once the car warmed up/you start using regen brakes it kicks off the engine more often. When I first start it up though, it runs until that battery is ready (5 mins?) and then will kick off. All that to say, if just backing into a garage at the end of a trip, it would likely be all electric but once you start it up in the morning to leave the motor would run until the battery is charged/ready and it would then kick off. Both of mine worked in reverse.
SpacemanSpiff
Tyreese
Mid-west
F-15 Eagle
Apparently Ford and Toyota each had patents the other needed access to, and so they struck a deal to avoid legal issues. More of a barter. Ford has over 100 patents related to hybrid systems.
BigB
BigB
Bryan
23 Ford Maverick
Thanks SL that’s a great explanation
Mavrcktrk
Southwest MO
VW TDI
There is no reverse gear in the maverick hybrid. The electric motor runs in reverse. Totally electric in reverse.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
... can drive up to a certain mph in electric mode only but does it do the same in reverse? I’m just wondering if I can back in my garage and pull back out without the gas engine starting to avoid exhaust fumes.
Yes, the traction motor is direct drive to the wheels (through about a 10+:1 gear train). Top speed forward is limited by motor redline. Reverse is limited to about 15 mph for reasons unknown to me. Given the ICE will usually be warm when you park, I see no reason it should be on.
FloodingdowninTX
Fusion
If you ever did that maneuver with a plain I.C.E. car, wouldn't there be a temporary smidge of fumes anyway? And is that not tolerable in the garage, health conditions allowing?
BigB
BigB
Bryan
23 Ford Maverick
Yeah I was just curious.
FloodingdowninTX
Fusion
It was interesting and I learned a little more from the discussion. My first hybrid too.
