The idea is to take your foot off the throttle (gas & electric pedal) briefly to go into electric mode and then gently apply pressure.Thanks Curious Gary...I knew most of what you said except cruise control..which I will try, but how can I get back into Electric if I can't let of the gas pedal, I mean electric pedal? I thought using your right foot to vary speed can get more charge to the battery (clear as mud?)
Your battery charges when you go down hill or apply the breaks. Then you can use the charge later to drive the electric motor.
You should set the dash board so you can see the EV Coach all the time. Are you seeing this? If not i will give you instructions.
I am not all that technical. You should follow members such as GPSMan for good advice on maximizing miles per gallon with your hybrid.
