So the actual amount of time will vary. A blanket 1 hour is not what I should have said. Different EVs have different charge speeds and battery sizes. Also road trip distances will vary. Lastly there is no getting around charging infrastructure not being there in many parts of the country. Most of those things will improve over time of course.Where do you get data of an hour at most for road trips? It takes an hour to take most batteries to 75% which of you're lucky gets 225 miles range.
Plenty of road trips need more than 500 miles... Meaning multiple stops and more than an hour added. And that's assuming your destination has chargers available close by, or it could get even more dicey (see remote camping trip).
The big things people ignore or don't realize though are:
1. EVs can actually go up to 80 or so % pretty quickly and if you plan your trip around shortest stops then you may stop more frequently but overall will have spent less time over all stopping. Yes you can charge 0-100% at every charger but the first 10 or so % and the last 20 or so % will all take way longer than the middle 70%.
2. For longer trips where you need to spend the night somewhere you can make that one of your stops and if planned properly you would get there with low charge and level 2 charge overnight to 100%.
It is totally feasible for on some trips to have similar time stopped when you factor in refueling, and actual rest (food, restroom, etc...). It just will depend on the vehicle. A GMC Hummer EV will take way longer to recharge due to its massive battery required to give that thing 300 miles range. A smaller car like a Hyundai Ioniq 5 will charge way fast for similar range.
If Ford could make a Maverick with 300 miles of range and DC Fast charging it will most certainly meet most use cases just fine. For anyone who tows long distance (Most don't as I understand) I would stay away from an EV at this time as range is cut in half.
