Hybrid Maverick brakes - replace at how many miles?
skinnyboy
Andy
Ontario, Canada
They squeak pretty much all the time, I just took it for an oil change and was told I will need new brakes that I am at 4mm in the back and 6 in the front. 2 months ago it showed I was at a 9 mm on both.
I feel like the one dealer is trying to hose me.
Wow, you must brake pretty hard for the pads to be worn that much on a '24. I would ask for the old pads back if/when you get them changed to keep the shop honest.
Cheers.
Womyn95
Nicole
Parshall, ND
2024 Ford Maverick Lariat
Cheers.
This dealership has tried to screw me over before so I will drive 2 hours to a honest dealership. I do not think it is my braking.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
How many miles do you have on your Mav? The brakes on the Hybrid do not get used a lot unless you hammer them on all the time, so the should last about 2x to 3x as long as the EcoBoost brakes. Most owners can expect to get at least 200k miles out of a set of pads, and possibly a lot more. Is it possible that you're riding the brake pedal all the time?.
Womyn95
Nicole
Parshall, ND
24,000 and don’t ride the brake pedal. I think the dealer I took it too had a tech that messed up
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
You don't get 200k from pads in the Appalachian Mountains.
I have 86,000 miles on a Ford C-Max hybrid and have never replaced the brakes.
I just had my 2016 Hyundai Sonota Hybrid in for state inspection. Brakes at 80% with over 92K miles. So, looking at first brake replace around 400K?
So I think it we be a while before my Mav needs brakes. Only at 7,000 miles.
The Maverick weighs a lot more than those vehicles. I learned today the brakes don't last as long if you have to slow down on long downhill slopes.
So to answer the OP question about the Maverick Hybrid (not about a C-Max or Sonata), yes - 45,000 mi front pads and rotors replaced under maint. warranty. Tread more lightly than I did...
https://www.mavericktruckclub.com/f...maining-80-highway-driving.61535/post-1313235
JMJB
JMJB
Fresno California
'22 VB XLT Hybrid with Sunroof
So ....a year and a half after I started this thread still no definitive answer ....I guess no one has wore out the pads on their MAVERICK hybrid .... 🤷
JMJB
JMJB
Fresno California
So Tom , were they actually wore out , or was a dealer just happy to replace them ?
tom_tucker
mid atlantic (VA)
Yup, turns out I'm the Donkey who wore out the brakes on a Hybrid at 45k. No way they would replace them for free right??? I'm still in denial about it but moving forward I'll be using the generator a bit more and a engine braking too.
Kenv24
Ken
2024 XLT
Straight from the 2024 Ford Maverick XLT Hybrid manual....well, kind of. LOL ***Replace the brakes on your Maverick long after you have traded or sold it*** :teehee: :teehee: :teehee:
babytruk
john
Curacao
2024 maverick Hybrid XLT
Do you run your Mav primarily in “normal” mode?
Cherokee
About 35% heavy city traffic, the rest was interstate. Average cargo load, 800 lbs.
2016 Ford Transit Connect XLT long wheel base.
I traded it in with 127,000 miles on the odometer.
Still on original brakes. This was a gasser, not a hybrid. About 45,000 miles was heavy city traffic.
Pedal felt fine, brake fluid reservoir was normally showing less brake fluid indicating the pads were nearing the end of their service life.
Brakes felt great.
All I had to do was look far ahead into the future, anticipate, and not tailgate.
I drive my Maverick the same way.
Timothyd
With regard to the regenerative breaking:
The regenerative system should really help in the mild mountains unless the battery is already charged. I know I use the brakes less in the Ozarks with all the ups and downs. I also get great efficiency there taking advantage of the hybrid.
The amount of regen that is possible doesn't matter between modes - if that's what you are suggesting.
Eco mode with stronger coasting regen just means you have less space to press the brake pedal and remain in regen.
Normal mode with less coasting regen just means you have more space to press the brake pedal and remain in regen.
Low button selected means max regen is used on coasting, and barely any brake press (depending on speed) is taking you into the pads.
Slippery mode with the least coasting regen actually shoves the stronger brake effect into the final 10-20% of regen - and if I use it even in flatter areas I'm constantly going into the pads because so little brake pedal movement is available.
Just did some incredible steep declines in AR back dirt roads.
Low did not feel comfy at all as I had to press the Go pedal to not slow up too much - but with 1000 ft drop off Cave Mtn Rd I couldn't do it with the curves.
Normal was just fine and light braking had me in regen all the way down. Son was shocked.
Timothyd
If the battery is fully charged would there still be regenerative breaking available?
Yes.
But it wastes the traction motor electrical on spinning the generator motor to spin the engine for air braking.
So no brake pressure on the lines, no pads used.
Also shocking - that didn't occur on that descent until almost the very end, and only up to 1500 abouts RPM.
Just enough level areas and curves that EV was used, to keep lowering the HVB down to abouts 45%.
