Hybrid- are you towing a camper?
Rod
Rod
Indiana
I have a hybrid.. looking at Rove Lite campers for short flat trips..
Jonny44
Jon
Minnesota
I've been looking at one of those, too (Rove Lite 14 FL). The only question I have on it is exactly how large the exposed footprint of the camper is. I don't think that the weight is any issue because I have towed the max allowable on my hybrid and it's never affected the vehicle in the slightest. I've had mpg's in the mid twenties at 70 mph (~2000#, 8 foot trailer, barely exposed).
Rod
Rod
Rod
Indiana
Yeah, I dont think the little truck can handle much wind resistance. Here is the data sheet That lists frontal considerations..
Ford Maverick Hybrid- are you towing a camper? F7DB8B67-2640-4F38-B70A-B5662619B77A
Jonny44
Jon
Minnesota
Yep, that's why I want to see one for measurement. 20 sq ft isn't much.
TedTX
Ted
San Antonio TX
Thats 20 sqft outside of the trucks cross section. Only a trailer smaller across than the truck doesn’t seem like the correct interpretation.
That just covers even normal height and 8ft and under, wide RVs that would be light enough to tow otherwise.
Rod
Rod
Rod
Indiana
The truck is about 5’ 6” high at the cab. 5’ 6“ wide. The Rove Lite is 8’ x8’..
So youve got about 2’ 6” above the cab height X 8’ width of the camper. Thats 20 sq ft of surface I think.. Doesnt take into consideration the 1’ 6” on each side of the camper exposed times 8’ tall. Another 20 sq ft total for both sides added to the 20 sq ft at the top is 40 sq ft..
GPSMan
Many
Considerations are just that.
Considerations are not exact limits.
Consider slowing down if you are towing something larger, for example.
GPSMan
Many
You have fixed limited horsepower.
You have fixed limited battery power.
You have fixed limited traction.
Your towing limit varies based on numerous other factors.
I can say with confidence the "ratings" are conservative.
Basic rule: Slow down = you can tow more.
LSchicago
Lloyd
IL
Basically the frontal area of a 4X6 trailer. 4' wide box, 5' high.
Nw_adventure
Salt Lake city
Good info- Just bought a Rove/lite -14B with the Off-road package which per specs brings the trailer from a total height of 8 ft 1 to 9 feet which seems a bit odd as it just goes from 13 inch to 15 inch tires -
FischAutoTechGarten
Peter
I've ordered an EB w/ 4K Tow...but I'll still ask this question here while you all are on the topic...
if my Maverick has a Midrise cap (ARE MX), will that provide a bit of a wind break for the frontol area of the trailer, diminishing the impact? Of course I understand that the CAP is also creating it's own drag and adding to overall GVW ... But it would seem with the cap the airflow is more stepped, such that the trailer face won't behave like a giant air dam.... Or am I being too optimistic?
Maverick2112
2025 xl hybrid.
I just towed a 1300 pound popup and that is about all I would feel comfortable towing. I don't have a lot of experience towing, however.
Ford Maverick Hybrid- are you towing a camper? popup (2)
bajesus8
Olathe, KS
2022 Lariat Hybrid Lux
