- First Name
- rslilly76
- Apr 20, 2022
- Corpus Christi Texas
- 2025 Maverick XL Hybrid Fwd
- Engine
- 2.5L Hybrid
got a pic of car scanner soc I haven't found itI'm not sure if the 2025 is different, but your state of charge (SOC) is probably below 85%, in which case the voltage will stay at 14.X when the truck is on, regardless of doors, lights, etc. However, once the SOC is above 85% the voltage will drop to about 12.8 unless you turn on the lights, fan, etc., that's when opening the door starts having an effect on the voltage.
Car Scanner does have a 12v SOC reading, that's what I'm using.
also in forscan you can change the state of charge from 80 to 95 a lot of audio people are recommendations that
