Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
NJBob
New Jersey
I never understood the need for a cabin air filter. Cars for many years did not have them. On the cars I have owned that do have them I have not noticed any difference. But you figure they must do something and can't hurt other than cost.
rslilly76
rslilly76
Corpus Christi Texas
2025 Maverick XL Hybrid Fwd
because it will keep your evaporator core clean, and if you've ever replaced that you'll understand doing a cabin filter instead. Also they do help with the dust in the car for allergies, if you use a charcoal filter it actually helps odors too. And yes they do work.
On a side note I'm loving my Toyotas after seeing this, they are way easier to get to and change. But this wouldn't prevent me from getting a Maverick
btas
Northern New York State
Ford Maverick, Ford Mustang, Ford Escape
Anyone see a K&N equivalent model yet? I’d rather replace mine with their washable ones.
I have a 2020 Ford Escape and the cabin air filter Motocraft part number for it is identical to the Maverick one other than the last two letters on the Escape which is -BA and the maverick one is -E. I have the K&N washable in my Escape which I'm taking out before I get rid of it when my Maverick arrives. Hoping it'll be a direct fit.
  • Like
Reactions: Dad
Dad
This is a pretty straight forward process but I thought I would post some images and information.
1. Open glovebox and empty the contents. On the right side is the damping lever. Using a trim tool as shown works best as it makes it easy to separate the lever from the mounting post. Push the tool in a little and twist to pry the lever outwards.
2. From the outside of the glovebox, push the tabs inward at the same time and rotate glovebox downward. You can now easily lift the glovebox up from its hinges and totally remove it.
3. There are plastic tabs on each side of the cabin filter housing. Carefully push each tab outwards to release the cabin filter door. The door is attached at the bottom with plastic hinges. Grab the tabs on the top and rotate the door downwards.
4. Remove the old cabin filter by grabbing the edges and pulling it straight out.
5. Install the new filter, making sure that the "airflow" arrow is pointed downwards. Rotate the door upwards and push in on each side to lock the door in place. Reinstall the glove box and re-attach the dampener.
This is what the filter looks like:
The Ford part number is: JX6Z-19N619-E. The OEM filter is made in the USA. MSRP is $29.95.
"FP-99" is also used to describe/verify the correct filter.
NEW FORD REFRESH95 CABIN AIR FILTER CAN HELP IMPROVE VEHICLE INTERIOR AIR QUALITY
new-ford-refresh95-cabin-air-filter.html
I have not seen these new filters being available yet for the Maverick. Will update this post when info & part # becomes available.
Great post! I learned something new today. Didn't realize the Mav had a cabin filtering system let alone how to change it out. Thank you for passing along this important information.
Peps
New England USA
2020 Volvo XC40
Thanks for the write-up!
A word of caution. When replacing your filter you don’t want a high performance “Hepa” filter. It will severely restrict airflow. I tried that with my Raptor and other Fords and immediately pulled it out and switched to an OEM (or OEM like) filter.
Can you elaborate on this? what kind of problems did you enconter. I was actually thinking of buying an HEPA filter because the maverick has the automatic shutoff of the recirculation and I really can no longer stand pollution/small from old vehicles. Probably you did not have ii installed long enough to ask you if it did eliminate the exhaust smell from outside, right?
Sleeper 7
Steven
NH
18 Fusion 14 Ram Dump 23 Maverick XL
And the mice cant chew thru the metal screen
KeinoDoggy
Elliot
Ohio
2022 Maverick Hybrid and Outback
Nice to see this (almost) copy of a late model VW design. After suffering thru the ridiculous replacement procedure required with our Fiesta and C-Max, this looks like a joy to replace.
All most exact procedure as my 2012 Prius.
OleFordGuy
Noticed this thread but can't seem to find a part # anywhere
https://www.mavericktruckclub.com/f...-new-refresh95-advanced-cabin-air-filter.867/
Johnkn
MD
Hi, the challenge with the Hepa style filters is that they severely restrict airflow from the cars vents. While not a scientific measurement, I would say perhaps only half the airflow in my Raptor even with the fan on high. with the fan on low, I could barely feel air movement. Search them out on Amazon, etc. and you'll notice that's a common complaint on the filters rated 'Hepa' (even through they may not be true Hepa filters). But your mileage may vary and it may be OK for others....
good luck...
MaverickResource
Trip
United States
www.youtube.com
2023 Tremor XLT, previous XLT Hybrid & XL Ecoboost
The HEPA filter probably restricted the airflow by being TOO GOOD of a filter. Air probably can't move through it fast enough
ToothGrinder
Ed
Southern California
2022 Ford Maverick XLT
Came to see how to do this job. Can’t believe the dealership wanted to charge $150 to do it. :LOL:
dalola
Retired
SE Ohio 🇺🇸
Thought I'd try a K&N for the cabin filter.....at $50, should pay for itself many times over the life of the truck. So far, seems to be working fine, maybe a bit more quiet, less restrictive than paper. Plan to clean it every-other oil change (10-12K).
Panther City Outdoors
Tejas
www.youtube.com
2023 Maverick XLT Hybrid
I used to be a tech writer, and your write up is an excellent procedural article. Short, concise sentences/instructions and good pictures, well done. How often do they recommend changing it?
