generalmgr
Wes
Clarion, PA
2023 Maverick XLT EB
I missing a function that others seem to have. I have tried every combination of settings. Right now it is working well, but displaying the traffic sign speed in the European style. I can live with that if I need to
Enabling TSR is a journey unto its own lol. Depends on the truck model and screen. I did hours of fiddling around and I still couldn’t figure it out. Eventually someone discovered that it works on xlt fx4 6” screens only if the TSR menu screen is disabled. Counterintuitive, but that’s what works.
Automan21
Mel
CT
‘23 XLT Eco AWD 4K Tow
I had it on for about a week then i started getting annoyed by it and took it off lol
RadioDoc
Fairchild AFB, WA
2023 Maverick XLT Hybrid Lux
I'm going to be interested to try out the TSR mod, but getting it set for the UK might be tricky. I need the European signs, but the speeds are in MPH. Otherwise going to get real funky when I hit that village 30mph sign and the truck is thinking it's supposed to be 30kmh.
The sign setting shouldn't affect it's ability to recognize signs, just the style it displays on the instrument cluster. The IC's unit mode might matter if you have alerts enabled, though, and were in euroland proper.
rallyshark
Donny
GA
2023 Maverick Hybrid
Does it only restore the low bass or does it affect other things as well?
The best I can determine, it mainly restores the bass below the 35-40 hz range. I can't tell much difference in the sound otherwise. If there are other differences, it is minor. I would only do this if I had a real sub installed. I wouldn't do it with a factory sub, or one of the popular super slim all in one subs because they can't handle the low stuff.
Deweyordeweynot
Dewey
Macomb, MI
Have you power-cycled the truck? Some changes to settings don't take effect until it's been shut down and restarted (just like computer programming changes)...I give it about 30 seconds off before booting it up again, even though it probably doesn't need that much downtime.
SloopJB
Waxahachie, Texas
2025 Maverick Lariat ECO/AWD White with BAP
Yes, I power cycle after every single change. Just habit. I probably only wait 5 secs before I turn the key back on.
Deweyordeweynot
Dewey
Macomb, MI
I kinda figured you did, but years of tech support experience has trained me not to assume anything. ;)
Old_Norm
Norm
Columbus Ohio
2023 Mustang Mach E 2023 Maverick Lariat
There is lots of useful information on MTC about using Forscan to make interesting and useful changes to the computer modules in our trucks. This post is not about using Forscan software or programming devices--you can find that information as a sticky in the Forscan forum.
This post is for those who don't speak hexadecimal* or are otherwise hesitant to change as-built codes (or for anyone who wants to make a quick change). I have compiled several changes you can make using "easy" (not as-built) mode. Instead of selecting a module through an as-built entry, look below it and there will be a module with the same name, but not as-built (not in all cases). Connect to that module. It's the same module, just named and accessed differently. The difference is that entries are in plain English [mostly]. Be sure to write the changes. Before doing any of these changes back up your as-built modules. Use at your own risk, of course, but these changes have all done well for me. I've included links in MTC for where more information can be found on these Forscan edits.
[*I know changing as-built modules does not require actually understanding hexadecimal--it's a figure of speech.]
Enable Traffic Sign Recognition (TSR)
IPMA:
Traffic Sign Recognition (TSR) - Speed Limit Information Function (SLIF)
Traffic Sign Recognition Mode - Camera data only
IPC:
Traffic Sign Recognition (TSR) - Disabled - Counterintuitive but important
Speed Limit Information Function (SLIF) - Enabled [if disabled you get European sign symbols]
https://www.mavericktruckclub.com/f...orscan-mod-confirmed-working.9399/post-748132
Thank you! My Forscan Holy Grail is enabling Eco Mode as default.
Buyerfind
Pembroke Pines, Florida
'22 Hybrid Lariat,No Deletes,10/5/21 order 11/5/22
All this info is great. Still looking for the ability to set cruise control to 15 mph. Currently, the lowest you can set is 20 mph.
Values like that are more embedded in the PCM programming. FORScan is not a magic wand; it can only modify flags that the programmers have specifically exposed mostly for option/trim/model configuration.
Metlcutr55
Ken
S W NH
23 XLT 2.0 eco cactus gray
I would so love Eco and Sport mode, and no auto shutoff at stop on my XLT, but I am way too electronically dumb to mess with Forscan. I'm in S W NH, where would I turn to have someone competent do this for me, and what should I expect to pay? Would it void warranty?
thev8man
IPMA:
IPC:
Adding Drive Modes
1. Enter ABS module and search for SDM
2. For SDM - ABS disable it
3. Depending which package you have installed enable the following if any say disabled
SDM - Mode 11 (Sport)
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
4. Check the DTC codes to see if you threw one
https://www.mavericktruckclub.com/f...-and-snow-confirmed-working.10229/post-211182
Stop being locked out of functions due to being in motion
ACM
Driver Restriction Configuration - Disabled
https://www.mavericktruckclub.com/forum/threads/for-your-safety-blah-blah-blah.35866/post-690772
"Disable" Key Fob Panic Button
No 2 press option on Mavs (that I can find; available on other Ford vehicles)
BCM (BdyCM)
Panic Alarm Mode - Lights Only
https://www.mavericktruckclub.com/forum/threads/disable-panic-alarm.21229/
Disable double honk when exiting running vehicle
BCM (BdyCM)
Double Honk on Leaving Cabine [sic] - Disabled
https://www.mavericktruckclub.com/forum/threads/disabling-double-horn-chirp.9208/post-555900
Enable ECO Coach (indicators about improving fuel economy)
IPC
Enable:
ECO Mode
Eco Coach Feature
Eco Coach with Efficient Drive Mode
https://www.mavericktruckclub.com/forum/threads/forscan-mod-–-enable-eco-coach-mode.25533/post-777948
All Windows Up/Down with Press and Hold Fob Button (Lariat only)
Enable:
BCM (BdyCM)
Global Close Initial
Global Close Vehicle
Global Open Initial
Global Open Vehicle
Global Window Close w Remote
Global Window Open w Remote
DDM
Global Window Close
PDM
Global Window Close
https://www.mavericktruckclub.com/f...nfirmed-working-lariat-only.11092/post-758399
I created this thread to help others not have to cull through all the various threads and posts with lots of replies and superfluous information. Please feel free to add to this list of Forscan edits, but it would be good to stay true to the attempt to include only instructions for easy mode.
Booyah 👊🏽 😁 👍🏽 🇺🇸
MAVRICKDAVE
ohio
23 XLT Oxford White Tremor 24 XL Atlas Blue Hybrid
IPMA:
IPC:
Adding Drive Modes
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
ACM
BCM (BdyCM)
BCM (BdyCM)
IPC
Enable:
ECO Mode
Eco Coach Feature
Enable:
BCM (BdyCM)
Global Open Initial
Global Open Vehicle
DDM
Global Window Close
PDM
Global Window Close
I wish i was smart enough to even thing about this stuff.. and i was a mechanic in the 70's :(
