FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL
EONR24
Swag
United States
2024 Ford Maverick XL
Hey everyone!
I just found a coding to enable the Ford Performance MYVIEW digital speedo on the 4 inch instrument cluster. I also found a coding to make it your default MYVIEW screen so you don't have to keep switching back to it every time you go for a drive. THIS CODING ONLY WORKS ON THE SMALLER 4 INCH CLUSTER!
MAKE FORD PERFORMANCE MYVIEW DEFAULT
1. Open IPC AS BUILT
2. Go to 720-17-02
3. Replace the second digit with a "5" as shown here
x5xx-xxxx
4. Write the changes and let Forscan correct the checksum
ENABLE FORD PERFORMANCE MYVIEW (Only 4 inch Cluster)
2. Go to 720-17-01
3. Replace the tenth digit with a "6" as shown here
xxxx-xxxx-x6xx
Here are some pictures of this screen and a picture of my original coding compared to the new coding!
UPDATE: Just added LAUNCH CONTROL and set launch control limiter to 3000rpm! As you rev the engine with Launch Control on, the MPH fills up with red the closer you get to 3000rpms. I will likely not use the launch control as I do not want to damage anything prematurely! Just wanted to see what the coding would do! Check out the coding and pictures below!I
ENABLE LAUNCH CONTROL BUTTON IN DRIVER ASSIST (Works on 4 inch CLUSTER only!)
1. Open IPC Easy Mode
2. Enable "Launch Control"
ENABLE LAUNCH CONTROL BUTTON AND ADJUST LIMITER
(only 4 inch CLUSTER screens)
2. 720-17-02
3. Replace the first digit with a digit based off of the diagram below and in the pictures. I replaced it with a "6" for a 3000rpm LC limit for example.
6xxx-xxxx
Launch Control Counter Limiter
0= LCCL OFF
1= LCCL 2500rpm
2= LCCL 2600rpm
3= LCCL 2700rpm
4= LCCL 2800rpm
5= LCCL 2900rpm
6= LCCL 3000rpm
7= LCCL 3100rpm
8= LCCL 3200rpm
9= LCCL 3300rpm
A= LCCL 3400rpm
B= LCCL 3500rpm
C= LCCL 3600rpm
D= LCCL 3700rpm
E= LCCL 3800rpm
F= LCCL 3900rpm
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL Screenshot 2024-03-25 at 6.57.08 PM
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL IMG_2939
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL Screenshot 2024-03-24 at 10.57.07 PM
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL Screenshot 2024-03-22 at 10.49.28 PM
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL Screenshot 2024-03-22 at 11.12.10 PM
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL IMG_2962
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL Screenshot 2024-03-25 at 5.52.51 PM
EONR24
EONR24
Swag
United States
Let me know how these coding changes works for you Maverick owners out there! This Cluster screen matches my ST performance radio screen too!
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL IMG_2781
Nexoidian
Aaron
2022 Explorer, 2018 WRX
Thanks for the info. I'm going to see if this works on my explorer digital cluster.
EONR24
EONR24
Swag
United States
Awesome! In the future, I may follow your thread and do the swap too! Thank you!
SloopJB
Waxahachie, Texas
2025 Maverick Lariat ECO/AWD White with BAP
Cool. Now I have something to do today. Isn’t life grand. How did you do the Performance radio screen?
How did you do the radio performance screen. Looks fantastic
EONR24
EONR24
Swag
United States
ENABLE ST ANIMATION (non-SYNC)
1. ACM (easy mode, not as built)
2. Change "animation type" to "ST"
If you have a Maverick with SYNC, you will need to go to APIM instead of ACM and change the splash screen that way!
SloopJB
Waxahachie, Texas
2. Change "animation type) to ST
I’ll give it ago. I have the large screen on my 24 FX4. I think it came with sync 3
EONR24
EONR24
Swag
United States
Check Out the forscan ideas for dummies thread ! @Old_Norm figured out how to do it with his Maverick and it has Sync! I'm pretty sure there are even more options for the APIM splash screen if you have sync compared to my non sync. Also, check out THIS VIDEO of all these splash screen options the Maverick might have! Thank you!
EONR24
EONR24
Swag
United States
The APIM Module was not showing up for @Old_Norm at first but he figured out how to get it working! Maybe he can guide you in the right direction if your APIM module is not showing up either!
TheShark
Looks like you have a XLT which means no Sync3, only the Lariat has Sync3. You should be the same as the XL.
EONR24
EONR24
Swag
United States
Is that how it works? So Lariat = SYNC, All non lariats = non sync? I get so confused on the trims, packages and differences! lol!
HolyCarp
DFW, TX
2023 Cactus Gray XLT Eco AWD FX4 4K
Hey everyone!
I just found a coding to enable the Ford Performance MYVIEW digital speedo on the 4 inch instrument cluster. I also found a coding to make it your default MYVIEW screen so you don't have to keep switching back to it every time you go for a drive. I have no idea if this will work on a 6.5inch cluster or not. Someone out there let me know!
2. Go to 720-17-02
x5xx-xxxx
2. Go to 720-17-01
xxxx-xxxx-x6xx
I have the 6.5" cluster. My IPC AS BUILT doesn't go up that high:
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL IMG20240325121445
SloopJB
Waxahachie, Texas
On my 24 XLT FX4, I went into ACM in easy mode and was able to change from default Ford flash screen to ST as the only other option. I am told that I will not have sync3.
So now I have below:
Ford Maverick FORScan Coding to make your 4 inch Cluster look COOLER AND LAUNCH CONTROL IMG_1307
SloopJB
Waxahachie, Texas
I have the large screen and cannot get 720-17-01 and 02. The display stops at 720-14-02
