- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
That's the idea - Accessory position will display the battery voltage - 11.x.Just the ignition is on so the battery has a load on it. When the ICE runs it goes up to over 15v. I think if I tested the battery by itself it would be over 12v. That's why I asked how they test the battery.
On, or Running position, will display the charging voltage - 14.x to 15.x
Has nothing to do with the ICE running, as power is supplied from HVB.
So when you said key On for the one picture - it should have been reading 14.x or above.
But your key was actually in Acc to get that reading.
Unless!!
You had drained the HVB down to 30% and it stopped providing juice.
You would have received a dash warning and electronics would have been turned off too.
