Foglights for 2025 Maverick Lariat?
Hybrid25XLTAWD
WA
25 XLT AWD Maverick Hybrid (ordered)
the kit will fit without issue. Likely need a new bezel to cover your cut job.
why do you continue to spew misinformation? the kit for 20-24 will NOT fit the 25's the front fascia is completely different!
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
He can’t help himself.
710-oil-614
Cal
2025 Hybrid AWD Lariat
Continue? My friend, that post you replied to was from September!! 🤣🤣🤣
Carlitos_92
mtree
www.themerlintree.com
'22 Subaru Outback, '25 Maverick XLT/FX4
With the XLT FX4 the DD lights were going to be a no-go anyway. Can light bars be viable fog lamps and/or driving lamps? On my Outback I had used a license plate bar with narrow lamps; any sensor issues putting something in this area?
mtree
Moving on to wiring. Does the Maverick have dedicated high low beam power leads - leads that can be tapped for auxiliary lamp relays?
Chops
Lobo
The on/off button for the Lobo Foglights fyi…
Ford Maverick Foglights for 2025 Maverick Lariat? IMG_0056
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
All you need can be found in my thread HERE for FX4 fog lights.
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Sticks
Shawn
St. Louis
No, there is not a discrete 12V lead for high beam. It is controlled by LIN communication. When the high beam is requested, the headlamp draws power from a wire that is always on (even when the high beams aren't).
You would need a LIN decoder to get a meaningful discrete high beam signal. I don't know of anyone on the forum who has bothered to try, though.
EDIT: or you could perform surgery on the headlight like this guy.
So the question is, what's going on behind that switch and where do all the wires go?
Most of the switch, including the Fog button, share a LIN bus instead of using discrete 12V signals.
Jhmcclos
Berlin, CT
2025 Ford Maverick Lariat
I was looking at options for fog lights and the Diode Dynamics ones look like the best ones i have seen. They are on back order according to their web site but it looks like they will be shipping soon.
Just remember that the 25 Lariat electronics are completely different than the XL/XLT and needs different wring to accept the different voltage requirements.
