- First Name
- Cal
- Oct 13, 2021
- Ohio...but I'd rather be in Boone.
- 2025 Hybrid AWD Lariat
- Engine
- 2.5L Hybrid
Thanks, Chief!Nice attitude lol
why do you continue to spew misinformation? the kit for 20-24 will NOT fit the 25's the front fascia is completely different!the kit will fit without issue. Likely need a new bezel to cover your cut job.
He can’t help himself.why do you continue to spew misinformation? the kit for 20-24 will NOT fit the 25's the front fascia is completely different!
Continue? My friend, that post you replied to was from September!!why do you continue to spew misinformation? the kit for 20-24 will NOT fit the 25's the front fascia is completely different!
Really surprised no one has linked this thread yet...why do you continue to spew misinformation? the kit for 20-24 will NOT fit the 25's the front fascia is completely different!
So the question is, what's going on behind that switch and where do all the wires go?The on/off button for the Lobo Foglights fyi…![]()
Here is the Lobo switch…So the question is, what's going on behind that switch and where do all the wires go?
All you need can be found in my thread HERE for FX4 fog lights.With the XLT FX4 the DD lights were going to be a no-go anyway. Can light bars be viable fog lamps and/or driving lamps? On my Outback I had used a license plate bar with narrow lamps; any sensor issues putting something in this area?
Diode is currently working on revising the bezel to fit the 25+ bumpers. It's supposed to be available in early 2026.Really surprised no one has linked this thread yet...
https://www.mavericktruckclub.com/forum/threads/2025-lariat-fog-lights.66531/
Anyway, so yes, they "fit" - but it is a bit of an arts & crafts project that surely many people will not take on. But it may be all the 2025+ folks get for a while, based on DD's comments.
No, there is not a discrete 12V lead for high beam. It is controlled by LIN communication. When the high beam is requested, the headlamp draws power from a wire that is always on (even when the high beams aren't).Moving on to wiring. Does the Maverick have dedicated high low beam power leads - leads that can be tapped for auxiliary lamp relays?
Most of the switch, including the Fog button, share a LIN bus instead of using discrete 12V signals.So the question is, what's going on behind that switch and where do all the wires go?
I found a guy that made a bezel to fit the 25's just finished installing them.The 2025 Maverick front grill area looks like it's begging for fog lights. Has anyone found and installed any yet?![]()
Just remember that the 25 Lariat electronics are completely different than the XL/XLT and needs different wring to accept the different voltage requirements.I was looking at options for fog lights and the Diode Dynamics ones look like the best ones i have seen. They are on back order according to their web site but it looks like they will be shipping soon.
