Fog lights installed!
fossil
ernie
ohio
You get a wrap and light bar Dodeboost? 😂 Stole this from Reddit. I bet that guy is wearing aviators.......
where's the cop bike rack?
TRUCKHEF
SOCAL
22' Ford Maverick XLT
This has more to do with the BMS. It's just important to attach accessories to the metered side of the post so the "computer" or BMS sees the draw of said accessory otherwise it will never compensate for that draw.
do you know which side is the metered side?
Dodeboost
Dodeboost
Southern California
2022 Maverick XL ecoboost AWD
Finally got my switches done. I used a Cali raised dual light bar switch meant for Toyotas. The switch is only rated to 3 amps so I used relays. I had to remove the screen to get the wires into the cubby which was a bit unnerving but it’s not that hard. You have to pull on it pretty hard and I ended up breaking a few of the clips. Found a YouTube video by the channel Gear Experiments which shows how to do this. I ran the wires in through the grommet on the drivers side firewall, under the center console, up behind the glove box and to the cubby. Removing the glove box makes this easier. I made the carbon fiber face plate and used epoxy resin meant for table tops as the top coat.
Switches: https://caliraisedled.com/products/dual-function-toyota-oem-style-amber-white-switch-small-style
YouTube video:
Ford Maverick Fog lights installed! 19369B25-9AB6-4D00-A90A-D1D65DCBBBF6
Ford Maverick Fog lights installed! 910A4DE3-7D22-40DC-B2E4-21B9A02744BE
Ford Maverick Fog lights installed! 09B80CD1-FDF1-466F-B3F2-8907812B18E8
switch wiring
Ford Maverick Fog lights installed! CDBA83F9-C18A-47AD-99EF-5BC778DFE6C7
Relays
Ford Maverick Fog lights installed! 6268FBE7-9A48-4F80-BE11-57C7364206D0
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
Nice.
I was wonder if one could get a switch from an Escape (or Bronco Sport) that has fogs. The center of the dial presses. Just not sure if that is a separate connection, like what you did.
Ford F150 , Ford Explorer and Ford Escape 2022 and Ford bronco have this switch and will work with the maverics
fahrfrompuken
Rick
Kyle, TX
@Dodeboost
Looks like you bought the JJC kit. You run the clear and yellow at the same time?
Dodeboost
Dodeboost
Southern California
@Dodeboost
Correct I’m using the jjc brackets. I usually just run the yellows. I have the whites aimed higher, about the level of the high beams. They’ll definitely blind other drivers so I don’t run them if there are any other cars around.
fahrfrompuken
Rick
Kyle, TX
Good to know. Thanks!
Dad
YouTube video:
switch wiring
Relays
Very slick! Super good look to your install. Thanks for not only pioneering this mod, but taking the time and effort to share your experience in such detail. Clearly, you're the Daniel Boone of Maverick modifications!
Dodeboost
Dodeboost
Southern California
Thanks dad!
  • Like
Reactions: Dad
doubleplay2025
Orange County, CA
Tesla Model X 100D, Honda Civic, 2022 Maverick XL
Nice setup, got to love what you can do with these trucks. On a side note, cant believe they are still running SkiDazzle. That was 30 plus years ago that my buddies and I went. I miss the South Bay. (Redondo)
Dodeboost
Dodeboost
Southern California
Thanks! I was wondering skidazzle was lol.
wax87
Stuart
Dallas South
2004 Avalon
Do you think you might want to put a leans cover over them, just to protect and make it easy to clean?
Dodeboost
Dodeboost
Southern California
Yeah I was just looking at them. They’re 10$ each and you can get amber, clear, or black. The lenses are also replaceable on these and you can switch up the beam pattern and color.
