First Recall - Trailer Module- Anyone Else?
Moombaky
Kentucky
2026 Ford Maverick Lariat AWD Hybrid, 2016 Jeep Wrangler JKU, 2016 Ford Focus
Ford Maverick First Recall - Trailer Module- Anyone Else? IMG_4457
Ford Maverick First Recall - Trailer Module- Anyone Else? IMG_0361
Cancunbadlands
Cancun
Cancun
2024 Lariat Tremor I got it, no fix at this time, I'm not worried since I don't tow anymore
Franklin
Frank
Cleveland Ohio
I just picked up my Maverick from the dealer and was told it should be available on or around May 29
Ecorydr
MO (Missery - home to those who voted for it!)
2026 Maverick Lariat AWD
Got this same update OTA on our '23 Superduty (finally) last month. Our new '26 Maverick was built mid March must have been updated at the factory prior to shipment.... no updates are pending on Ford app or Infotainment screen - yet.
Redline
Upstate, NY
I also got one for my 23 XLT Tremor. I'm hoping to get it done at the same time as the backup camera recall. And I'm hoping they'll replace my battery, as well.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Got it a month ago for my 22. I do tow, but have never had this error and trailer lights have always worked. Will most likely get it done when a fix is available.
Red Eyes - Wide Shut
West
2024 XLT
Had mine updated / done on Friday with an oil change. Added to my list.
rlbender01
Jacksonville NC
2026 Maverick XLT, 4K, FX4
Had the recall done on my 2026 XLT FX4 a couple of weeks ago (Jacksonville NC). Software update, took them about 20 minutes.
KenE
Ken
Mount Washington, KY
2025 Maverick Hybrid Lariet
See links at bottom of this thread. Yes I got it, no fix at this time.
I received the recall notice. Fix WAS completed at dealership in April. Don't understand "no fix yet"? I would expect all dealerships to be able to do it at same time? Perhaps not. Bottom line, fix is available. My dealer did that one and the park brake recall same day, one trip.
Packer Bill
South Dakota
The fix is available for 25-26 models. No fix is available for the 22-24 models.
KenE
Ken
Ah, OK. Thanks for the clarification. My bad assumption 🤭.
SafetyGuy
Andy
Manitoba
Good day
I just had my Mav in the shop yesterday for the Trailer Module update to be carried out, along with a couple other things (like the rear passenger door window trims pulling apart at the joint, upper rear corners).
Funny thing is, I have a change to my trucks 12 volt charging level when it is running. It was noticed immediately when I started it up to leave my dealer's lot.
I have an inexpensive volt meter in the dash 12 volt power port which I know indicates 0.1 volts high.
Since March my 12 volt charge levels when driving were varying between 15.1-15.2 volts (corrected from displayed value). (Over 15 volts is not good for an AGM battery).
(I do regularly recharge the battery with an appropriate AGM 1-7 amp Canadian Tire charger).
As soon as we started up the truck, I noted that it was charging/system voltage was at 14.59 actual! By the time we got home 20 kms later it was indicating 14.19 volts (actual).
(I metered the battety-boost points under the hood after the truck had shut everything down 2 hrs later and it read 12.8 volts....12.8-13.0 volts is considered fully charged).
I started it twice since and same ballpark voltage readings.
I was working around and in and out of the truck yesterday (this would slowly draw down the 12 volt battery, waking the truck up repeatedly).
I just got a call from my wife who is out and about (and knows about my 12 volt system...ahem...interest) to let me know that the truck was charging the battery at 15.1 indicated volts (15.0 volts actual).
She knows that over 15 volts is bad, and now knows the indicator reads 0.1 volts high, and called to let me know. She is a keeper, alright!
This is great, as that is the maximum normal charge voltage for an AGM battery.
I just don't know why the values changed as this module has never come up as being associated with the charging levels (or lack thereof) for our trucks.
The only work that was done (having to do with electrical or modules) was the Trailer Module Reprogramming, recall # 26C10B.
Has anyone else noticed a similar change/improvement in their Hybrid 12 volt charge profile after the Trailer Module reprogramming?
I ask as there are other current threads that discuss the charging values, causes etc, and their short comings for our trucks (just turn on your headlights day and night when driving and that helps...long story short!)
I realize many don't look at things like this, but it doesn't hurt (much ;-) to ask, right?
Have a good day,
Andy
