Recall Number: 26C10 TRAILER MODULE REPROGRAMMING
dbbii
Don
Tampa, FL
2023 Maverick
I know this isn''t specifc to Mavericks, but my wife has a Lincoln MKX. It had a recall. Dealer sent out their mobile service. What was supposed to be a 30 minute job turned into an hour. Then, the next time we drove the vehicle we got all kinds of error messages. Called dealer back. Opps. Software update didn't work correctly. We will send a different tech out.
Becker300
Robert
Eden Prairie
2023 Maverick XLT - Alto Blue
My trailer lights and brake signals quit a month ago. I received the over the air update last weekend and hooked up my trailer to test afterwards. Everything is now working correctly.
Hi. I had the recall fixed also, but my running lights do not work on both trailers. Any thoughts?
dsweet3331
USA, Texas
Maverick XLT
So, did you have the recall done “over the air” or when you went into the dealership?
Have to tested the trailers on another vehicle or with a 12 vdc jumper ?
If all that checks good, and only the marker lights do not work then possibly a trailer marker lamp fuse.
Becker300
Robert
Eden Prairie
Recall was done at the dealer. Same issue on 2 trailers.
dsweet3331
USA, Texas
Maverick XLT
Dealer should have checked output of all circuits and trailer brakes, if you have the towing package. Do you have both the flat 4 circuit plug and the RV 7 surcuiyt round plug?
before I took it back to the dealer I would verify that the trailer plugs (both of them) if you have do not have running light output. When the modal cased the problem only the 7 circuit plug was without electricity, the 4 circuit plug worked normally.
Hot Runr Guy
West Chicago, IL
Can you clarify this please? When I had the 23C04 recall done on my '23, neither plug had power to the trailer parking/running lights.
HRG
dsweet3331
USA, Texas
Maverick XLT
My recall was done over the air. The only plug that did not work was the 7 way round plug. All circuits were down or off. The 4 prong plug did not have brake and turn lights but the running lights did work. If I remember the recall stated it affected trailer brakes, turn signals and trailer brake lights only.
Hot Runr Guy
West Chicago, IL
Thanks. The recall I had done back in 2023 was definitely a hardware problem, not solvable by a software update.
HRG
dsweet3331
USA, Texas
Maverick XLT
This is the current recall I was referring to:
Key Recall DetailsRecall Numbers: NHTSA Campaign 26V104 / Ford Campaign 26C10Affected Vehicles: 2022–2026 Ford Maverick (alongside select F-150, Super Duty, Ranger, Expedition, Navigator, and Transit models)The Defect: “The Integrated Trailer Module (ITRM) may lose communication with the vehicle when a trailer is connected. This can lead to a complete loss of trailer brake function and, or inoperative turn signals and brake lights.” as detailed by the Maverick Truck Club Forum.Safety Risk: Reduced trailer visibility and a lack of trailer braking capabilities can increase the risk of a crash.
