- Jun 15, 2024
- Central California
- 2024 Lariat Hybrid white on black
- Engine
- 2.5L Hybrid
I agree they should be AGM, but the Hybrid needs RC, not CCA. The High voltage battery starts the hybrid ICE.Ford should have used an AGM battery as the stock battery on the Hybrid instead of a wet cell. Point 1 who in their right mind would put a wet cell battery under the back seat inside a car????? Yes the stock Hybrid battery is vented under the floor, but a really bad decision. The AGM battery will not out gas, and it is non-spillable. Point 2 is that the AGM (H4, 140R) battery has 50% more cold cranking amps as the wet cell OEM battery. Point 3 is that the AGM battery discharges at about 1/3 the rate as the OEM wet cell. Lastly, the software "fix" will be a tweak on charging of the 12v battery and probably to reduce functions that discharge the battery. Getting an AGM battery improves performance and safety, and that coupled with the "to be" software fix should put this issue to bed.
