Drive belt on the 2.5L engine
clavicus
I don’t think anyone can conclusively say there is an aux heater, but there appears to be a substantial fuse for it.
I went back in the manual (draft?) to search and all I got was this note on “why is the engine running” section lol
pg. 416
Ford Maverick Drive belt on the 2.5L engine A7A16B09-2BED-4F4A-A9DE-B348264FAFA7
@midcoastme How sure are you that the 12v can start the ICE under any circumstances? I think its a higher voltage AC to run the stators to move the smaller starter/generator motor to turn the crankshaft and get the ICE going? Not saying I know one way or the other but that’s the first time I’ve heard of that. Apparently it’s a relatively small battery that isn’t sized for a conventional ICE starter duty.
The battery management system wouldn't allow the HV batt to get that low under most circumstances. Even if you drove to the lowest SoC possible and then stopped there's still about a 30-35% 'floor' that's reserved. Remember lithium batteries really don't like being fully discharged. The older NiMH hybrids before a reserve system was implemented had a manual jump function.
midcoastme
Jim W
The Mid-Coast of Maine
2 PT Cruisers & Maverick Lariat Hybrid.
So to recap, did we collectively conclude there is an auxiliary cabin heater that turns on to give immediate cabin heat while the ICE warms up in a cold environment? Or is the jury still out?
The only experience I have so far is with my 2 C-maxes. In the past 5 years of owning the hybrid, there have been maybe 2 occasions where the hybrid battery had been depleted due to some extensive slow driving, A/C on high, in electric mode. Upon restarting, the gas engine shuddered a bit and came to life, then remained on until the hybrid battery had been sufficiently charged. According to the gauge the C-max hybrid usually operates between 1/3 and 2/3 charge, i.e. driving on the interstate at 65 mph, fairly level road, the car will cruise on electric until the battery drops to about 1/3. Then the gas engine comes online until the charge reaches about 2/3, then it's back to electric. Perhaps it was the main battery that started the engine those times...I'm only guessing since the power gauge had showed just about empty. The Maverick is likely a completely different animal since we're talking 6 years difference.
midcoastme
Jim W
In answer to the question about remote starting and the heater warming up the cabin, the C-max energi that I have was my commuter car for the last 2 years. I worked until 1 a.m. and it could be pretty chilly during the winter. I would start the car with the MyFord app on my cellphone at about 12:50 a.m. When I clocked out and went outside the gas engine would be running, windows and mirrors clear, interior cozy. Step on the brake, push the start button and the engine would usually shut off. I would then drive out of the parking lot in EV mode until the battery got down to about 1/3, and the gas engine would fire up again. The electric heater element would only bring the temp gauge up to the first line...running the gas engine would bring it up to normal.
I'm hoping the Maverick will be similar.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
If so, it's the first time Ford's done that, IN A HYBRID.
It's not in my HF45 Escape. Folks keep talking about C-Max Energi, a plug-in that naturally has resistive heating. Absent a plug-in Maverick, no resistive heater.
In a hybrid that's got a plug-in option, I'd expect a common electrical harness. It's not uncommon to have unused circuits. Bodes well for the Maverick line-up.
Wire4money
Las Vegas
2005 Wrangler
It’s very common in modern cars. My 2019 Tacoma had it, as well as my previous and current Audi.
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
It’s very common in modern cars. ...
Got any documentation specific to Ford hybrids? I get cabin heat when the temperature gauge moves, not before. Even so, it comes up fast enough that one would be forgiven for thinking there's an aux heater somewhere.
The HF45 coolant capacity is much less than EcoBoost, 5.5 qt. vs. 9.9 qt., so it inherently heats up faster. I have a block heater, and I struggle to see a benefit in warm-up time or cabin heat. In fairness, I tend to stay home when it's below 0.
Wire4money
Las Vegas
2005 Wrangler
Didn’t say it was common in Ford hybrids. I said it is common in modern vehicles. I gave you 3 vehicles I’ve owned in the last few years.
Wire4money
Las Vegas
2005 Wrangler
Far as documentation to Ford hybrids, look at the owners manual in the fuse section for the 2022 Maverick.
scotty
pompano berach fl
dodge caravan
All entertaining discussion, I wish I could think as many of you do, but God made me different. but unless I missed a thread; I'm looking for an answer to the question: Does the maverick's heating system in the cabin sufficiently get to at least 76 or so degrees within 5 minutes.
Timothyd
I found this article at the Ford Authority website.
https://fordauthority.com/fmc/ford-...ratec-engine-family/ford-2-5l-duratec-engine/
2.5L Duratec Engine
The Duratec 25, also known as the Mazda L engine, is a 2.5-liter naturally aspirated four-cylinder from Ford Motor used to power midsize cars, cargo vans and sport utility vehicles, also known as SUVs. Featuring a dual overhead cam (DOHC) design, in an inline configuration, the Ford Duratec 25 engine has been part of the Ford Duratec engine family since 2008, but was first introduced on the North-American market in 2009.
This engine was developed in partnership with Mazda (part of the MZR family), but under Ford ownership, which explains why it was used in a variety of different vehicle applications from one brand to the next. Such variations also mean that a slew of different technologies were grafted onto the engine as it evolved, things like the Atkinson cycle, hybrid technology and adaptive knock control for improved fuel efficiency. The Ford Duratec 25 engine powers the following vehicles:
  • Ford Escape
  • Ford Fusion
  • Ford Transit Connect
  • Lincoln MKZ
Duratec 25
The Duratec 25, or Duratec 2.5L I-4, is an evolution of the Duratec 23. 'Duratec 25' should not be confused with the similarly named 2.5L V6 Ford Duratec. The new Duratec 25 is an inline 4-cylinder engine design that is identical to the Mazda MZR 2.5L. The bore and stroke have increased to 89mm x 100mm and as such now displaces 2488cc | 151ci. Power has been increased to 171hp@6000rpm and 171lb-ft@4500rpm torque. A Hybrid Duratec 25 will be replacing the Hybrid Duratec 23.
Fuel saving features include adaptive knock control and aggressive deceleration fuel cutoff.[3]
Overview
MetricValue
Engine familyDuratec
Displacement2.5 liters
AspirationAtmospheric
Configuration & cylindersInline configuration, four cylinders
Vehicle engine orientationTransverse
Valve configurationDual-overhead cam (DOHC)
Assembly sitesDearborn, Michigan, USA / Chihuahua, Mexico / Hiroshima, Japan
PredecessorMazda F engine
SuccessorFord EcoBoost
MetricValue
Bore89 mm
Stroke100 mm
Compression ratio9.7:1
Max power @ RPM175 hp @ 6,000 rpm
Max torque @ RPM172 lb-ft @ 4,500 rpm
Cylinder headAluminum
Cylinder blockAluminum
Camshaft driveChain
VehicleTransmissionDrive WheelsPower@ RPMTorque (lb-ft) @ RPM
Ford Escape (2009 - 2019)Six-speed automaticFWD / AWD170 @ 6,000167 @ 4,000
Ford Fusion (2010 - 2013)Six-speed manual / Six-speed automaticFWD175 @ 6,000172 @ 4,500
Ford Fusion Hybrid (2010 - 2013)Continously variable automatic (CVT)FWD156 @ 5,550 (191 hp combined)136 @ 4,000
Ford Fusion (2013 - 2019)Six-speed automaticFWD175 @ 6,000175 @ 4,500
Ford Transit Connect (2014 - 2018)Six-speed automaticFWD169 @ 6,000171 @ 4,500
Lincoln MKZ Hybrid (2011)Continously variable automatic (CVT)FWD156 @ 5,550 (191 hp combined)136 @ 4,000
Mercury Milan (2010 - 2013)Six-speed automaticFWD175 @ 6,000172 @ 4,500
Mercury Milan Hybrid (2010 - 2011)Continuously variable automatic (CVT)FWD156 @ 5,550 (191 hp combined)136 @ 4,00
This engine compartment is going to take some getting used to. Beyond the basics one of the first things I'm going to do is get a micro amp meter and check across that troublesome harness to battery connection. I hope they've addressed that.
NJBob
New Jersey
So why does my house have a heat pump not a resistive electric furnace?
It's because you are not creating heat. You are moving any heat that is outside of the home to the inside of the home. Some heat pumps do have electric heaters as they dont work so well below 40 degrees. Electric resistance heaters are 100 percent that does not mean it is free..
Sykotyk
Ohio
In my experience (without having the recall done that removes some of the flaps) the engine reaches operating temperature (3 or 4 bars on the lariat screen) very quickly. And heat works extremely well but it will kill your fuel mileage as you're running the engine only for heat and not for propulsion.
I know it sucks, but I just get in the car and go. Within a mile of engine actually running when it's needed to run its hot enough to have the heater blowing hot air.
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
Yes.
clavicus
Yes, in my experience. For example, in my mild climate in central NC it does get below freezing. My commute is short, like 5 minutes. I start feeling warm air after 2-3 minutes or so but it doesn’t really ramp up to the full heat until around the 4 minute mark. Heated seats and heated steering wheel in my Mav are awesome in this situation. Often I’d just leave the heat setting off since I’d only have like 1 minute more to get to work once the heat is really going — not for any efficiency reason, but because I’d usually just forget to turn on the fans since I didn’t want them blowing cold air on me in the beginning.
