Door locking incident...
dochawk
doc
Las Vegas
What exactly is being sprayed with silicone,
On one of our dealer rows, it would seem to be the chubby lady by the curb with shorts that don't quite reach her thighs, who walks up to any car that slows down . . .
Kenv24
Ken
2024 XLT
Mine happened to the service manager and he never pushed the door at all. Simply pulled the handle and released it without touching the manual lock. They actually stick together one out of a few hundred times.
I've had fusions with the same mechanism and zero issues.
Thankfully it happened to him while I was explaining it was an issue.
No way this happened. He locked it with his hand the same way hundreds of us have done by now. If it was "sticking" together with "something"...we would have seen and heard it by now. "Self locking door....you are NOT the father"........:clap::clap::clap:
The amount of force to push that lever AT the pivot point almost, where it touches the handle release base, would require not only a binding mechanism, but a messed up spring.
Maybe they reversed the springs - stronger one on handle, weaker on the lock lever - and it's massively binding.
To claim this is a big problem is ignoring how many admit upon exam they did indeed push it.
This should be an easy video next time it happens.
Personally I'd think the snap release would be safer, and a slow lowering of the handle would cause more friction with the lever.
Just a video of it trying to move like it's almost grabbing - would be vastly different than it appears anyone else.
Hey - some owners do have a unicorn Maverick.
And that's a very different symbol and headlights!
Timothyd
I used to lock my drivers door all the time by accident. Now, hardly ever. And, if I do, I just unlock it from the drivers side backseat door.
That's because you came to the realization that you were locking it by accident. At this point the holdouts will never realize or admit to it. It doesn't matter that the coding for autolock is nowhere in the Maverick. Unless you're driving it at 13+ miles an hour. Then all doors will lock.
Ok, the amount touching between handle and lock lever isn't as much as I imagined, not that much.
Maybe there is more internally since obviously the handle has to move the lever open.
Also - there is much less spring resistance on the lock lever than I thought, it is a pretty easy push at the end - but still, near the pivot point?
Hmmm - already greased up!
Perhaps Glenn could test throwing some sand/dirt in there!
For the really Ford tough truck users. Once you get done doing what the commercials show - gotta be some dirty hands.
Ford Maverick Door locking incident... 1787676756990-xn
There is literally no way for the lock lever to retract / pulled back and relock when you're releasing the door handle NONE.
MaverickDragon
Grand Canyon, AZ
Well, here we are at post #129 oops that was just added.. Now at post #130 on this weeks currently hot topic, when the "issue" or in this case "non-event" was completely and thoroughly, as well as eloquently addressed by the esteemed Dr. Glen Baker in post #4, leaving a courtroom of even easily influenced jurors no alternative but to find that the Maverick was not guilty of any and all charges...
The only item of potential interest remaining, will be if this thread makes it to page #10..:wink:
I'm sure we'd all be curious as to what that update was?
That would be interesting to see.
Hopefully, some folks can find the coding FORScan.
MaverickDragon
Grand Canyon, AZ
Hopefully, some folks can find the coding FORScan. That would be interesting to see.
Hmmm... I'm thinking that a coding change to enable an automatic lock of only a single door, that being the driver's, would only serve to be annoying rather than serving any legitimate purpose.
A software engineer might find that update was grounds for dismissal, or in the case of an AI bot designer, that memory would be wiped.
Perhaps if the Earth were actually flat, it might make sense... :wink:
I know right?
If you really think about it. Having a code that only "auto-locks" the driver's door is totally ridiculous.🤣🤣
I guess the explanation is easier than backpedaling.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
I know right?
Why do I always hear Black Oak Arkansas in my head when a "auto lock" thread pops up?
Glen Baker to the rescue
Go Glen Baker! Go Glen Baker!
MaverickDragon
Grand Canyon, AZ
I think the driver door autolock feature was mentioned in the Superman comic that introduced the Bizarro world, where the feature made sense... Otherwise, not so much.
On the plus side, the thread continues onto to page 10 .... It ain't dead yet!
