My thoughts exactly, Still waiting for my Hybrid scheduled for build from FordOrdered the LEDs last night. Just need a truck to put them into.
No hyper flashing?I installed these in the BRAKE and in the TURN SIGNAL sockets, just to see if they work, before I installed them in BACKUP lamp sockets (2022 Mav XL). They fit easily and did NOT throw any codes.
not sure what you mean? Are you implying the bulbs are white? And the red color is just from the red housing?Yes, they are available in red, but, fyi, each of the 3 bulbs in my Maverick XL taillamp housing were clear.
Also depends on if the taillight is led or not. A lot of the brake lights now are led while the reverse light stayed halogenthese are the LEDs that fit WT21/7W spec on the F150. Believe they’re the same as Maverick.
I do not have my rig yet so cannot try. https://www.diodedynamics.com/rear-turn-tail-light-leds-for-2021-ford-f-150-four.html
It’s been confirmed as halogenAlso depends on if the taillight is led or not. A lot of the brake lights now are led while the reverse light stayed halogen
Interesting. I wonder if the clear makes them brighter? Would the red LEDs not be as bright?Yes, they are available in red, but, fyi, each of the 3 bulbs in my Maverick XL taillamp housing were clear.
If I had to guess you’ll need resistors. They may not throw a code, but they will probably have hyperblinkIt’s been confirmed as halogen
They’ll be just as bright most likely, but if you put a high powered white led bulb in there it will probably look more pink than redInteresting. I wonder if the clear makes them brighter? Would the red LEDs not be as bright?
Thanks for this info.
I know. They were asking about brake and turns as wellFor the back up lights-no resistors needed
Turns MAY need a resistor but I don't believe brakes would. There is no hyper flash with brakes unless you're pumping the brakes.I know. They were asking about brake and turns as well
Holy cow haha I said brakes and turns because it’s most likely the same socket. Of course brakes wouldn’t need itTurns MAY need a resistor but I don't believe brakes would. There is no hyper flash with brakes unless you're pumping the brakes.
