Broken Axles - Poll
If you've had your axles broken, select your setup AND how many times they've failed.
  • Total voters
    69
fossil
ernie
ohio
I suppose as we can't see the number of views on the thread but.. 13 failures in 2 days on what I have to assume is very small group of active MTB members participating is sufficient. Ford has an actual problem they are ignoring, kudos to Radmav for shinning a light 👏
Interesting my orig post has as many likes as the total # of reported failures of which 11 are hybrids.
main problem I saw with the poll was no one without a failure can view the poll results.
MM Mav
Amy
Great Lakes Region
@fossil why couldn't any interested party just click the View Results button below the poll 🤔?
Please note I haven't voted in the poll, because I haven't confirmed a CV failure though I do have some front end vibration between 30ish-50ish sometimes.
Ford Maverick Broken Axles - Poll Screenshot_20240713_090712_Adblock Browser
Ford Maverick Broken Axles - Poll Screenshot_20240713_090905_Adblock Browser
Ozarkbeard
Huh? I have not had a failure and I have not voted. I can see all of the results.
Make sure you're logged in when you're trying to view the results. If you can't, reload the page. If that doesn't work, clear your browser cache and reload the page again.
Joeneonturbo
Joey
Turlock, ca
Ford Ranger, Dodge SRT-4
Also wld like to know from the owners with broken axles is when did it happen? Mav hybrid owner here for 18 months and only 9k miles driven. I’m wondering shd I drive harder before warranty ends.
acelee1895
Adam
2023 Ford Maverick Hybrid Lariat, 2015 Ford Fusion
I put stock height but I have one size up tires. Not sure if that was the correct response or not
restlesstexan
Patrick
add my stock 2022 Hybrid Lariat to this list. 35980 miles.
shaking/vibration at highway speeds, took it in to the dealer and got the diagnosis that it needs new front axle shafts.
Bwicka
Lakeside,ca.
Trying to get some actual numbers of failed axles and with which setup. It's hard to get any type of accurate numbers by reading all the threads. If you've had an axle or two, or three, or four, fail on you, please fill out the pole.
Noticed there are no tremor failures.
I can obtain tremor axles
Pz6z- part numbers if anyone in San Diego area would like to see if they would swap out, I would be willing to help with comparison and install.
I believe they would be a direct swap .
Stock at an nz6z- part number and are like 40-60 each cheaper than my cost of the tremor axles .
Copy of tremor cost of a pair I bought for mock up wider axles.
Ford Maverick Broken Axles - Poll IMG_3841
So far I have an additional 2” lift over stockish of angle added to my tremor and have done $10k miles with the 255/75/17 tires and no problems .
Tom 71 Maverick 24
Northeast Ohio
I'd like a definitive answer with side-by-side images of a tremor vs regular AWD axle shaft. I mean, if it's stouter and compatible, it would be almost a "no-brainer" swapping in the Tremor part. But that's a big if.
bgn
WA
Dealer just called. Replaced one side. Vibration still there. Replaced the other and it's now gone. 20k miles with oversized tires, no lift.
Bwicka
Lakeside,ca.
So would I , someone needs to bring the standard anxles and a standard truck over and we can compare.
Al I can do is offer.
I have a spare set of tremor axles , just don’t see a need for me to go buy a set of standard.
I do have comparison with calipers and pics against some hybrid axles somewhere on this site and they are approximately 1/8” thicker on shafts and ball ends too.the tremors also appear to be a 5 or 6 ball slider joint where the hybrids are a 3 ball.
Jacobrippey1
Jacob
Surprise, AZ
2022 Maverick FX4 EB
Came here to post that the dealership replaced both axles. Slight lift and oversized tires, FX4 EB. 37K miles.
Bwicka
Lakeside,ca.
There was one tremors actually are a 10 ball slider with a cge setup similar to porshe style .
I also accidently clicked on this poll thinking it had a option for no problems on the tremor box amd tried to remove the vote , but wouldnt remove it so mrmagoo is only one with tremor fail .
Skeeter163
Don
Hertford NC
2017 Escape
Does the model year make any difference?
I believe lowering or lifting does.
Waterick
Laurens county SC
Remember, the axles fall under the power train warranty so you do have more time and miles than just the 3/36.
