Aftermarket Axles: Show your interest!
Tremor N.C.
N.C.
My drivers side in front also failed (1" leveling kit, but the wheels/tires I'm running are almost 10 lbs lighter than what was on there originally - so those weren't a factor). Ford told me the front right axle is a 2 piece and can tolerate the lift from the leveling kit, but the drivers side is one piece and the splined end was at its limit and stripped out.
My hope is that there will be a "longer travel" cv axle offering at some point (like there are for so many other applications). Even something with 40 mm of give (like the passenger front has) would be more than adequate for all but the most extreme suspension changes
Yes, I am all in for any upgrades possible, I have spoken with cvj, will rebuild to spec but have better boots, I emailed gator 3 times but never heard back, I know someone out there can do it. I tried a hi-speed test & when I came in grease everywhere. I haven't been off road any yet, but will soon.
Bigdadyd67
ILLINOIS
2016 Mitsubishi Outlander
Update as of 7/15/2024
CVJ - I've decided to send CVJ a set of Hybrid Maverick Axles instead of the FX4/AWD axles. I need a VIN from a Hybrid owner that has had an axle fail already before I can do this. Long story, but it won't cost you anything.
Gator - Gator will be getting the AWD/FX4 Axles from me and it sounds like they'll be about the same price as CVJ once it's all completed. It'll be interesting to see these two companies do their research and to see their findings.
Update(s) as of 7/15/2024
CVJ
- I will be paying out of pocket to purchase a set of FX4 front axles to send to CVJ for them to use for R&D. Once the axle set is recieved, they will be pinpointing the failure points and modifying as necessary. Once complete, they will offer this as a service to anyone else. If someone is willing to pay for a set of Hybrid Axles to send to them for R&D, please contact me via DM.
Gator - Similar setup as CVJ, but I'll be paying out of pocket for a pair of FX4 axles to send to Gator for R&D. Once the axle set is received, they will be pinpointing the failure points and modifying as necessary. Once complete, Gator will order a few sets to keep in-stock and you can just purchase the modified set directly. If there is enough interest and sales over time, Gator will then move to create new custom axles for sale. This will only happen if sales can support the costs involved for tooling and R&D into a custom set.
By now, we all know that the Ford Maverick has a weak point in the OEM Axles. While many of us have had our axles replaced under warranty, there are still even more that have had to pay out of pocket. As more and more of us drive past our OEM powertrain warranty, this is becoming more of a concern to many owners. Ford has not updated the design which leads to the high possibility that the replacement axles will fail again. With no aftermarket options, all we can do as owners is fork out the cash to replace the axles every time they break.
The main issue seems to be the outer boots popping off and flinging out all of the grease, which in-turn roasts the axel. Please reply if you have personally experienced any other issues with your axles outside of that. Please do not reply with "I read somewhere" or "I heard from a friend". We all know that information can get mixed up when it's being recommunicated, so please only respond with personal experience.
Mt 2022 XLT FX4 is once again at the dealership for a toasted axel, and I'm over it, so I'd like to take on the responsibility of soliciting owners and manufactures about aftermarket options. I have more than a decade's experience with working with aftermarket performance manufactures so I'm confident I can get some actual answers to the right questions. I've reached out to three different companies in an effort to create good/better/best options and here is what my work has yielded thus far.
(Images are just examples from the corresponding company)
GOOD
CVJ Axles
What they would offer
Purchase a set of new OEM Ford Axles and dropship them directly to CVJ Axles in Denver, CO. They would take those OEM Axles and modify them to correct the failure points once those points were identified in their R&D. Machining a deeper groove for the outer boots, replacing the boots with a longer one, ect. It would all depend on what they deem to be necessary for the Maverick.
What they would need to start
CVJ would just require one pair of new OEM axles to use for R&D. This testing phase would take about a month to complete and once they have finalized their solution, this axel service would be available to everyone with a reasonable 1-week turnaround time from the time they receive the new OEM axles.
Benefits of this option
• Most likely the most cost-effective solution. After the initial purchase of the axels, this service/upgrade/modification would be projected to cost somewhere in the range of $300-$800 for the pair including shipping.
• The quality of the remainder of the axle would be OEM quality, and not cheap chinese replacements from an auto parts store.
• Lowest cost and effort for production
Price
~$300 - $800 on top of the cost of new OEM Axles which can be found at Ford Parts sellers online for about $120 per side. All in, the cost for this option would range between $540 to $1040. I might just go ahead and order a pair and send them a set to get started with.
Better
Gator Racing Axles
Gator would offer a rebuild/upgrade performance modified set of OEM Axels. If sales hold over time, Gator would then produce a whole new axle from the ground up.
Needs a set (Or one of each version) to start with to see where the weak points are. R&D would be about 90 days. Once the R&D Is complete, Axels would be available for purchase on their site.
• Proprietary racing grease that will hold even with a torn boot*.
• 6-Month Warranty - Extended to 1 year if there's not too many problems
Price
+-$600
BEST
RCV Axles
100% custom built high-performance CV Axles specifically designed for the Ford Maverick made from 4340 Chromoly Steel.
In order for them to move forward with creating axles for the Maverick, RCV would need to see some interest in the form of 30 pre-orders. Once that benchmark was met, RCV would need a Maverick in their area that they could use for a portion of their R&D which is located in San Luis Obispo, California. R&D would take approximately 6 months from beginning to production ready.
• LIFETIME WARRANTY*. This does not include boots that have been neglected for an extended period.
• Boots are replaceable
• The entire axle is serviceable
• Years of tested designs with their Bronco and Ranger applications as well as many others
• Stronger than OEM
• Custom applications available for those that may want to run extended arms, or have extreme off-road or racing needs.
• The orange boots just look cool are are very fitting for the Maverick lol.
Price
~$2,300 - This is very much on the high-end of pricing for any axle, but it seems to be worth it after reading several reviews from RCV Axle owners. This price could also come down substantially if there is high interest. This ballpark price was given with the idea that it would be approximately the same number of buyers as their toyota applications. The lowest price axles they have run around $800 for the pair, but those are for high-demand Jeep applications. I don't think Mavericks will ever get close to Jeep numbers for sales, but perhaps we could get enough to get the price down in the future.
Please reply if you are interested, and which option you are interested in. Please also include if you are a Hybrid or EB, FWD or AWD. I will create lists under each option to gauge which option has the most support, and from that point, I can move forward with coordinating with that particular manufacturer.
Hopefully, we can all have an option that works for us that won't leave us stranded 327 miles away from home with a sick dog in the truck with us in the middle of nowhere while on a road trip to see family.... (I promise I'm not bitter at all... fet up is more like it).
Expressed Interest:
1. RadMav - 22 FX4 - CVJ or Gator
2. CaptainCoffee - 23 Tremor - Any
3. Strikingracerx - Any
4. Jamie O'Neil - CVJ
5. Dale Lewis - CVJ
6. Tyler Cohen - Any
7. Dignam - CVJ
8. David Metz- CVJ or Gator
Bunchahoopla
Jeremy
Springfield MO
2022 Ford Maverick FX4, 2023 xl hybrid, 2025 tremor
I would be down for RCVs. I won’t lift the Mav until they are available. AWD tremor here
wax87
Stuart
Dallas South
2004 Avalon
CVJ
GOOD
CVJ Axles
Price
Better
Gator Racing Axles
Price
+-$600
BEST
RCV Axles
• Stronger than OEM
Price
Expressed Interest:
5. Dale Lewis - CVJ
7. Dignam - CVJ
Any of these for Hybrid Mavs???
DavesMav
FL
Unfortunately, the OP (@RadMav) sold his Maverick a while ago. No idea where they left off with this or if it went anywhere at all. I'd reach out to the companies directly for more information and see if anything's in the works.
Someone else needs to carry the torch for us on this idea.
kidshelleen
Sam
'02 Cape Horn 17', '18 Prius Prime, '90 Miata, '25 Mav Lariat hybrid/AWD/4K
Ah... so that's why this thread went stale. I just put a deposit on a Lariat/Hybrid/AWD/4K, and am digging into what lifting options/suspension upgrades are available. New CV shafts certainly seem to be a prereq.
I'm not ready to pick up the torch, but will support the torch-bearer...
-ks
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
Hybrid fwd bump
