Battery issue
TacoTanium
Earth
XLT
You purchased yours in Apr 2023 and starting to get these issues in Oct. 2024. That's a very long time. My first battery lasted 6 months, my 2nd is starting again at just over 2 months. My 2nd battery is AGM.
Jeff W8
Jeff
Western Washington
It’s literally removing the negative battery cable, then the positive battery cable, swap batteries, attach positive battery cable, attach negative battery cable. You also have to attach the vent tube. Then Reset BMS.
Thanks for this information. I bought the AGM battery using the Amazon links others provided (the seller wanted confirmation that I knew what I was doing). The biggest challenge for me was removing the plastic around the battery as the obstacles made that a big pain.
Everything is working! The one thing I noticed is that to reset the BMS, it required 4 or 5 brake taps instead of the 3 mentioned in the post.
Russ B.
Russ
Coronado, CA
2024 Maverick XL - 2000 Toyota Sienna - 2006 Nissan Altima
Good morning! If you'd like to, go ahead and send us a private message with your VIN and dealer info and we’ll look into this deep sleep concern. Thank you!
Ford Motor Company how do we send a private message to you?
Did you learn anything from your request to FORD for instructions on sending a private message? ((Thanks, in advance, -Russ))
Considering the issue continues of undercharging since this old thread - no they did not learn anything they took action on.
Also it was probably earlier than that request to contact them - but Ford presence left the forums.
Timothyd
Welcome to the club of deep sleep issues. There many threads discussing this issue with possible solution. I think the best solution is to replace your battery with a third party AGM battery. Ford does not even make an AGM battery for the Maverick hybrid. If you search this forum, you will find recommendations for a replacement battery and how to install it.
On sale this black friday.
