Renho17
Ren
Hybrid Mav
unfortunately, the rain doesn't listen to me all that well when I am driving...
True, but it hasn’t rained since I got my maverick so I have no clue on that.
adawalli
adawalli
Adam
2017 Ford Explorer Platinum, 2010 Toyota Prius 3
Thanks for the update - I think "only leaks at the tailgate" avoids telling the whole story in your case - I think we would like to figure out ways to mitigate the issue (mine's really not that bad, but I know it can be improved. Hopefully without epoxy!)
Renho17
Ren
Hybrid Mav
Well i am assuming There is No way to make it not leak at the corners unless extra stripping or epoxy.
CenTexMav
Clint
Previous: Subaru WRX, Challanger RT, RAM 1500
I have the Ford hard roll-up... It leaked along the tailgate regardless of how I adjusted it. I ran a strip of side molding on the edge of the tailgate and it made a big difference. There is still somewhat of a leak on the corners but the tailgate seals so much better.
Ford Maverick Bak Revolver X4S Hard Rollup Installed on Lariat Hybrid - impressions review PXL_20220625_220909094~2
Ford Maverick Bak Revolver X4S Hard Rollup Installed on Lariat Hybrid - impressions review PXL_20220625_220622448
Mabcim
Rochester, NY
22 Maverick Lariat 2.0 AWD; 20 Escape SEL 2.0 AWD
It goes under the glass which is awesome - the seal is a bit bumpy and not yet flush since it hasn't been in the sun
Would you might measuring the length of your rails?
Yours are closer to the glass and closer to the tailgate than might. They seem longer than mine. My box indicates it was just made in July.
adawalli
adawalli
Adam
Ford Maverick Bak Revolver X4S Hard Rollup Installed on Lariat Hybrid - impressions review 439B2099-1556-4E14-A70E-6D74C56E7151
Mabcim
Rochester, NY
Just got my X4S today; returned the Pro X15.
Anyone else’s tailgate ‘hit‘ the end of the cover and ‘force’ it up a little when tailgate closes?
The rails had shims on them already, near the top. Seems that causes the rails to tip down slightly; which might be the cause.
Do your latches get slightly caught on the rear latches? Thinking I might need to move the rails closer to the tailgate. Which would mean the front bracket won’t be contacting the bed.
Mabcim
Rochester, NY
adawalli
adawalli
Adam
I did not have to do this on my Maverick, but had to do exactly this on my brother-in-law’s F150 with the X4S
Smooth_criminal
Michael
Johnson city
1966 ford f100, 2022 Ford Maverick ecoboost
I installed mine yesterday. Fit was perfect, front seal tucked under the glass, tailgate closes easily. However both plastic corners were broken. I contacted them and they are supposed to ship new ones. I also plan to glue the corners one since they are easily broken.
Mabcim
Rochester, NY
Glad yours went smoothly. Did the rails have ‘foam’ shims on the back of the rails already (closer to the top)?
Smooth_criminal
Michael
Johnson city
Not that I recall, I will look later today.
Mabcim
Rochester, NY
Mabcim
Rochester, NY
kmish203
Jeep Renegade
I posted this on another thread but I used J-B Weld Plastic Bonder in black to permanently attach the plastic caps on the end. I think it's a much better option than just using some super glue.
Ford Maverick Bak Revolver X4S Hard Rollup Installed on Lariat Hybrid - impressions review JB Weld
