Are Dash USBs powered?
Groo
UP of MI
26 XLT
Ivetried both USB ports at the center bottom of the dash, and neither charges my phone. It does data connect and fool my phone into thinking its charging, but does not charge. Is this a problem or are they data only?
Mangoal_Support
Diamond Sponsor
North America
discord.gg
2024 Maverick XLT
Typically, those ports are designed more for data, but they do support charging as well. The power output is often pretty limited compared to a dedicated charger
Marty
2026 Ford Maverick Tremor
Don’t use the USB use the ā€˜USB-C’ port.
Mine charges my IPhone just fine with its 3.0 amp 5 VDC output.
Standard USB-C / BC 1.2: Delivers 5V at up to 1.5A–3A (7.5W to 15W).
I Never used the standard USB port because I don’t have anything that old anymore.
FWIW my IPhone charges fast up to 80%
Then slowly up to 100% for the batteries sake.
But like the Mavbrid’s power battery I don’t charge past 80% for longevity of the cells. My phone has a charge limit setting.
The exact VDC and Amps available depend on the hardware generation and connection type: [1, 2, 3]
    • USB 2.0: 5 VDC at 0.5 A (500 mA)
    • USB 3.0 / 3.1: 5 VDC at 0.9 A (900 mA)
    • USB BC 1.2 (Battery Charging): 5 VDC up to 1.5 A
    • USB-C Standard: 5 VDC up to 3.0 A
    • USB Power Delivery (USB PD): Dynamically negotiates voltages of 5V, 9V, 15V, or 20V (up to 48V in newer extended specs) at up to 5.0 A, providing up to 100W–240W of power.
MavGeek
Western NY
2026 Ford Maverick XLT AWD Hybrid, 2024 Ford Edge ST-Line-AWD
This has been my experience also.
matmondro
Mathieu
Vassar, MI
The regular USB port charges my phone. Not very fast though lol...
Mark’s Mav
Tennessee
2025 Hybrid Lariat AWD
Some usb cables are data only. Try a different one.
tiktokbrainrot
around
91 F250, 20 GLI, 25 Mav XLT
Yes, both should do 5v/3a charging.
If you download Ampere, you can see how many amps your phone is pulling. If it is only pulling 3-500ma, then there is a communication error.
USB uses a negotiated handshake between the charging device and the charger to agree on max allowable amperage and voltage. Some cables do not agree with some devices, typically the cheaper cables do worse, but not always. There could also be dirt, dust, or a wire with bad connectivity preventing communication and thus using the fallback charge rate which barely moves the needle these days.
Hootbro
Don
Delaware
2025 Ford Maverick AWD
My Samsung will charge off the USB A port fine. Also my understanding the newer iPhone's will no longer charge off a USB A port anymore and has to be a USB C.
Check symbols at data/charge ports and on your cable ends....
= A USB data and charge symbol typically combines the standard USB trident logo (for data and general connection) with a battery outline or lightning bolt (for power delivery and charging).
Groo
UP of MI
26 XLT
I wasn't aware of that. Thanks.
